Drop in speed.
tarren
Drop in speed.
Would the stats below indicate a drop in speed from a rock solid 12+megs, for the last 10 months, down to 4\5 megs?
Operational Mode  ADSL2+
Upstream 1167 kbps
Downstream 14617 kbps
SNR Margin (Upstream) 6.6 db
SNR Margin (Downstream) 6.0 db
Line Attenuation (Upstream) 10.6 db
Line Attenuation (Downstream) 22.0 db
Thank You.
Fixes: 62
Re: Drop in speed.
No
Have you checked the current line speed https://portal.plus.net/my.html?action=data_transfer_speed and are you testing via wireless
tarren
Re: Drop in speed.
Hello Oldjim,
Just checked;  Current line speed:12.9 Mb.
I am testing via wireless.
Thank you for your reply.
Fixes: 10
Re: Drop in speed.
What speed do you get wired?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
tarren
Re: Drop in speed.
Gentlemen, happy to report that by changing my wireless adapter, all is now well. Many thanks for your replies.
