Draytek Vigor 2860n works with Plusnet VDSL
robsonthejob
Hi - Anyone using this router - Latest firmware installed etc its connected ok but attainable download rate is 23088 - actual rate is 14333, speed is worst than my old failed router (dead stick so cant look at old settings) - Im very close to Green box, new phone cable to telegraph pole and im only a short distance to exchange - a few hundred yards any ideas to improve the speed/settings ?
Fixes: 17
Re: Draytek Vigor 2860n works with Plusnet VDSL
This is ADSL2+ not VDSL2?
Sounds like the connection has been banded, and it requires Plusnet to remove the banding.
Plusnet Staff
Plusnet Staff
Fixes: 116
Hi there, first of all a warm welcome to the community forums.
Spot on. I've tested your line @robsonthejob and the service is banded at:
Profile Info: WBC 7M - 14M Low delay (INP 0) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+)
I'm not identifying the cause of that, so I've removed it. Let us know how you get on.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
robsonthejob
Hi - Seems to have done the the trick. See below now 20+MB speed test confirms - thanks. The question is now Why was i banded in the first place ?
Its more annoying as i have contacted PLUSNET several times regarding speed and the fact i cant get fiber yet.
Why did no one suggest this before ?
ATU-R Information
         Type: ADSL2/2+
         Hardware: Annex A
         Firmware: 05-07-02-08-00-01
         Power Mngt Mode: DSL_G997_PMS_L0
         Line State: SHOWTIME
         Running Mode: ADSL2+ Annex A
         Vendor ID: 00000000 00000000
ATU-C Information
        Vendor ID: b5004946 544e71c8 [IFTN]
Line Statistics
  Downstream             Upstream
Actual Rate 22750 Kbps 1089 Kbps
Attainable Rate 22916 Kbps 1092 Kbps
Path Mode Interleave Interleave
Interleave Depth 64 1
Actual PSD 20. 0 dB 9. 9 dB
  Near End                  Far End
Trellis ON ON
Bitswap OFF ON
ReTx 0   0
SNR Margin 6 dB 6 dB
Attenuation 11 dB 5 dB
CRC 27 0
FECS 1320 s 0 s
ES 19 s 0 s
SES 0 s 0 s
LOSS 0 s 0 s
UAS 0 s 0 s
HEC Errors 0 0
RS Corrections 0 0
LOS Failure 2 0
LOF Failure 0 0
LPR Failure 0 0
NCD Failure 0 0
LCD Failure 0 0
NFEC 156 255
RFEC 0 4
LYSMB 274 5780
Plusnet Staff
Plusnet Staff
Fixes: 116
Happy to hear that's worked. I apologise that the banding wasn't spotted before.
A line will usually become banded if a fault happens. I tested your line and I wasn't identifying any problems. It could have been the fallout from your old router that failed?
 Plusnet Staff
robsonthejob
Hi - Most of teh time the broadband is ok but a few times a day it keeps becoming unresponsive and video/vpn drops out then recovers.
Sometimes it fails a few times them stabilizes again - any ideas ?
Fixes: 22
I suggest that sight of your router stats (again) would be a useful starting point please.
Fixes: 162
Checking your line we saw a number of disconnections on Thursday but these have become much less frequent. Are you still experiencing the same issues?
 Chris Parr
 Plusnet Staff
