Draytek 2760N VDSL router working fine on plusnet fibre
- Re: Draytek 2760N VDSL router working fine on plus...
16-02-2014 2:59 PM
After various soul searching and googling, I've managed to replace the BT modem and PlusNet router with 1 device - the Draytek 2760N all in one VDSL Capable router.
Mandatory router upgrade out of the box - you can get the recent firmware from the Draytek website
IMPORTANT
You have to upgrade the firmware to 1.2.0.1
Then its just a question of modifying the web based front end setup as Admin as follows:
Navigate to Network > WAN > DSL:
Amend as follows:
Profile Type - VDSL2
Protocol PPPoE
Username [your unique id] @plusdsl.net
Password - Your PlusNet password
VLAN ID = 101
Also Under Network > WAN > DSL Mode > Physical Type
set it to 'VDSL2 Only' to improve connection speed
DNS
Under Network > LAN > Ethernet
DNS Server = Custom
I have 3 entries for the PlusNet DNS (you can add whatever DNS servers you prefer obviously)
212.159.13.49
212.159.13.50
212.159.6.9
Hope this helps anyone else with Drayteks 2760 \ 2860 series get connected faster than I did
IMPORTANT
Amend as follows:
Protocol PPPoE
VLAN ID = 101
DNS
DNS Server = Custom
212.159.13.49
212.159.13.50
212.159.6.9
Message 1 of 3
(8,762 Views)
2 REPLIES 2
Re: Draytek 2760N VDSL router working fine on plusnet fibre
16-02-2014 3:36 PM
Nice. Keep us posted if it holds up well etc, i'm looking for something new to replace the default.
Draytek's latest SoHo router range supports both ADSL and VDSL broadband (including BT Infinity) as well as 3G/4G USB modems (as the main WAN, or as fallback). A huge range of features includes gigabit LAN ports, NAS, VPN, full dual stack IPv4 and IPv6 support - and of course Draytek's famous firewall and web content filtering.
As usual, the Vigor 2760 is available in three versions, the base model, the 2760N with a full W-Fi implementation supporting 802.11n, 802.11g and 802.11b and all the usual authentication protocols - and the 2760VN which has wi-fi and Draytek's famous VoIP capabilities. This listing is for the Vigor 2760N.
Specifications:
Physical Interfaces:
LAN: 4-port Gigabit (10/100/1000 Base-T)
WAN: RJ11 socket - supports ADSL or VDSL
VDSL:
G.993.2 (VDSL2)
G.993.1 (VDSL)
G.997.1
VDSL Annex A, Annex C, Annex M
VDSL Profiles: 8a, 8b, 8c, 8d, 12a, 12b, 17a, 30a
OLR, UPBO, DBPO, US0
Loop diagnostic mode
ADSL:
ANSI T1.413 Issue 2
ITU G.992.1 (ADSL G.DMT)
ITU G.992.5 (ADSL2+)
ITU G.992.5 Annex M
ADSL Annex A & Annex M
3G/4G (Cellular) : Compatible with many USB 3G/4G modems; check for current list
USB: 2 USB 2.0 Ports (for printer, storage and 3G/4G modem)
Printer sharing compatible ith most standard USB printers (not MFPs)
VoIP: Two RJ11-BT-type sockets for phones ('v' models only)
Two removable aerials for Wireless LAN ('n' models only)
Maximum Firewall Throughput : Approx 90Mb/s
WAN Protocols : PPPoE, MPoA & PPPoA
WAN Failover : Switch to 3G when DSL down
3G modem/account required
VPN support:
Up to 2 outgoing tunnels (LAN-to-LAN)
Protocols : PPTP, IPSec, L2P, L2TP over IPSec
PKI Certificates: Use X.509 Digital Signatures
IKE Authentication: Pre-shared key (PSK), Phase 1 agressive/standard, Phase 2 selectable lifetimes
Encryption: MPPE, DES, 3DES & AES (56 & 168 bits)
Authentication : MD5 & SHA-1
DHCP over IPSec
Dead-Peer-Detection (DPD))
No extra licencing or additional VPN client costs.
Interoperability : Compatible with other 3rd party VPN devices
Firewall:
Stateful Packet Inspection (SPI)
Content Security Management (CSM)
Port Redirection & Open Ports
Policy-based IP Packet Filter. Fully configurable policies based on IP address, MAC address (source or destination),
direction, bandwidth, remote site
DoS/DDoS Protection
IP Address Anti-spoofing
Object-Based Firewall
Bind IP to MAC address
Hardware NAT
NAS (Network Attached Storage):
Internal Memory : 40Mb
External Memory : USB memory key (not supplied)
Supports Samba & FTP file access
USB memory NTFS and FAT32 supported
Supports multiple FTP user accounts
FTP accounts can be read-only or read-write
Samba access allows access to whole memory
Wireless LAN:
IEEE 802.11n, 802.11g, 802.11b
Frequency : 2.4Ghz MIMO 2T2R
Encryption : WEP, WPA, WPA2
WPS - Push-button method
Hidden SSID
MAC Address Access Control
Wireless Client List
Access Point Discovery
WDS (Wireless Distribution System)
Multiple SSIDs
Wireless LAN Client Isolation
WMM
System Management:
Web-Based User Interface: Integrated server for router management (via HTTP or HTTPS)
User-configurable dashboard
Telnet/SSH : Command line control and configuration
Configuration Backup/Restore
Built-in diagnostics: routing table, ARP table, DHCP table, NAT Sessions Table, data flow monitor, traffic graph, ping
diagnostics, traceroute
Firmware Upgrade by local HTTP
Syslog Logging
Vigor ACS-SI Centralised Management: TR-069 compatible for ACS platform
Compatible with Smart Monitor Traffic Analyser : Windows software for up to 100 users
Bandwidth Management:
Traffic Shaping: Dynamic bandwidth management with IP traffic shaping
Bandwidth Reservation: Connection or client based
Packet Size Control
DiffServ Codepoint Classifying
4 Priority Levels (Inbound/Outbound)
Individual IP Bandwidth Session Limits per user/group
Bandwidth Borrowing
User-defined class-based rules
Web Content Filtering & CSM:
URL Keyword Blocking: Blacklist or Whitelist
Content Type Blocking: Java applet, cookies, Active-X
Block P2P Applications (inc. Kazza, WinMX, Bittorrent)
Block Instant messaging
Block access of web sites by direct IP address (thus URLs only)
Block HTTP download of compressed, executable or multimedia files
Web Content Filter: GlobalView filtering of 64 web site categories (e.g. adult, gambling sites etc.). subscription required
(free trial included)
Time Scheduling: Blocking rules can be activated based on time schedules
Routing Functions:
IPv4 & IPv6 Dual-Stack
DNS Cache/Proxy
DHCP Server
DHCP Options: 1,3,6,51,53,54,58,59,60,61,66,125
IGMP v1/v2 & Proxy/Snooping
uPnP: 30 Sessions
NAT: 20,000 Sessions
NTP Client with DST Adjustments
Dynamic DNS : Updates DDNS servers with public IP address
Port-Based VLAN
Client/Call Scheduling : Real-time clock, with NTP updating schedules access or connectivity
Wake-on-LAN : Passed from WAN to preset LAN device
Operating Requirements:
Temperature Operating : 0°C ~ 40°C
Storage : -25°C ~ 70°C
Humidity 10% ~ 90% (non-condensing)
Power Consumption: 16.3W Max (Vigor2760Vn)
Dimensions: L182 * W125 * H40 (mm)
Operating Power: 220-240VAC (to DC with supplied Plug-Top PSU)
Warranty : 2 Years Manufacturer's RTB included
Please note we supply only UK-specification products, with UK-specification plugs etc. - and UK warranty support.
Specifications:
VDSL:
G.993.2 (VDSL2)
G.993.1 (VDSL)
G.997.1
ADSL:
ANSI T1.413 Issue 2
ITU G.992.5 Annex M
VPN support:
DHCP over IPSec
Firewall:
DoS/DDoS Protection
Hardware NAT
Wireless LAN:
Hidden SSID
Multiple SSIDs
WMM
System Management:
Syslog Logging
Packet Size Control
Bandwidth Borrowing
Routing Functions:
DNS Cache/Proxy
DHCP Server
uPnP: 30 Sessions
Port-Based VLAN
Message 2 of 3
(2,879 Views)
16-02-2014 3:52 PM
It was reduced at BT Shop \ Dabs to £97 over Christmas when I purchased it - crept back upto £140 since but keep an eye out
8 days solid uptime so far.....
Name Status Up Time
[DSL] PVC1 Up 200:01:18
DSL Info Name DSL Info Data
Line mode VDSL 17A
Line Uptime 08:08:02:09
Downstream Line Rate 80000 kbps
Upstream Line Rate 20000 kbps
Obviously with a big spend on a new router you may prefer to go for a router with 5ghz wifi. I found the Draytek 2.4Ghz MIMO a lot faster than the plusnet supplied router anyway.
Draytek 2760N
Good explanations here:
http://compnetworking.about.com/od/wirelessfaqs/f/5ghz-gear.htm
5 GHz vs 2.4 GHz - The Bottom Line
5 GHz and 2.4 GHz are different wireless signaling frequencies that each have advantages for computer networking. Higher frequency networks are not necessarily superior to lower frequency ones, however. So-called dual band hardware combines the best of both types of hardware by integrating both types of radios into the product.
Name Status Up Time
Line mode VDSL 17A
Draytek 2760N
Message 3 of 3
(2,879 Views)
