Downtime tonight - 4th Aug
- Downtime tonight - 4th Aug
Re: Downtime tonight - 4th Aug
11-08-2009 3:29 PM
Perhaps for the next trial it will be possible to raise tickets that go direct to the team in charge of the trial.
11-08-2009 4:10 PM
Quote Shouldn't have to.
Why not, if it's a trial?
Quote Perhaps for the next trial it will be possible to raise tickets that go direct to the team in charge of the trial.
We have separate teams for provisioning, faults and support and certain members of those teams have been trained to deal with the new 21CN service. In addition, once confirmed the tickets are addressed directly to those people.
12-08-2009 10:50 AM
So now have working Internet, but speed is worse than it was before the fault. Used to get a sync speed of 4000 - 6000, yesterday was on 3500, and today looks like it has dropped down to 3000. Have updated my ticket to ask support what can be done to try to increase this.
I would like to have something good to say about 21CN, but it appears it only benefits people who already have a good connection speed.
Up to this fault I have had no issues for the 2 years I have been with PlusNet, and been quite happy. As this is the first time I had to deal with support, I'm sad to say it has not been a pleasant experience. Hopefully I will be back up to speed soon and be a happy surfer again, and not have any issues for at least another 2 years.
12-08-2009 12:34 PM
The best thing to do is reboot the connection once daily, ideally in the morning as initial sync speeds tend to be higher then. This should (provided the line remains stable and synced at a higher speed) uplift the line profile within a couple of days.
12-08-2009 3:22 PM
(Sufficient to impact negatively on your profile).
Everytime you reboot you are gambling that the connection won't throw a wobbly
12-08-2009 4:02 PM
I'd be inclined to agree with what Crucibleofevil just said about this.
Since last Saturday when my line returned to ADSL2+ speeds in excess of 11000(d)/1100(u) with SNR of 9(d)/6(u), I have rebooted the router each day, very early in the morning. Then totally out of the blue this morning another line 'bounce' and my sync rate went from 11499/1188 to 9648/1169 with SNR of 12/6.
I have had a ticket open since 24 June, 2 BT Openreach engineer appointments, neither of which found anything wrong with my line. Prior to 24 June, I had been on the trial since 1 May and seen sync rates of well into the 12000s.
I just wish someone could explain to me what on earth is wrong with this 21CN/ADSL2+ thingy
TTFN
toulouse
12-08-2009 4:16 PM
Quote Surely, it's only better to do this (within reason) only if you've experienced a re-sync to a significantly lower speed within the last few days?
AFAICR we've always recommended doing this during the training period as the DSLAM sets the profile according to initial sync speeds.
Quote Everytime you reboot you are gambling that the connection won't throw a wobbly
Yep. And every time you cross a road you're gambling with your life.
12-08-2009 4:24 PM
Can you canfirm for those that are on the WBC trial that they are connected to a MSAN and not a DSLAM and the 10 training period is for the MSR and FTR to be set and the profile is just a by product of this as the profile can change after the 10 days but the MSR and FTR can't.
12-08-2009 4:38 PM
Quote from: itsme Can you canfirm for those that are on the WBC trial that they are connected to a MSAN and not a DSLAM
Yes. Sorry, that was my mistake (though the DSLAM still plays a part in the connection AIUI)
Quote from: itsme and the 10 training period is for the MSR and FTR to be set
Yes.
Quote from: itsme and the profile is just a by product of this
Yes.
Quote from: itsme as the profile can change after the 10 days but the MSR and FTR can't.
That's correct.
12-08-2009 4:49 PM
Quote from: orbrey
Sort of, this http://www.theitp.org/UserData/root/Files/2007Vol6Prt2_01.pdf explain how DSLAM can be involved but only in relation to FTTC the 21CN trialist I would say are all on MSAN as this is the only option for POTS and BB, refer to figures 2 and 4.
12-08-2009 6:42 PM
(Actually, I'm rather pleased at getting this).
I've discovered that a resync - caused by me doing a router reboot bumped the noise margin up and the speed down by 4Kbps.
The noise margin has since been backed off to a current 6.9dB
Notice that the sync speed does not vary, but the noise margin does - even in training
15-08-2009 10:05 AM
Still since the 4th August outtage my speed is 20-25% less and this fact is being totally ignored.
Am I missing the point?
Tony
16-08-2009 5:56 PM
Plusnet Technology
17-08-2009 9:50 AM
I have left my router on for about 3 days now without rebooting, and have had a connection without dropping of 4400 Sync Speed. But my IP Profile is still on 3000. I have not been rebooting my router once daily in the morning as previous advised on this forum, as the people working on my support ticket think my connection keeps dropping, and don't seem to be able to progress my ticket until I have had a good connection for about 3 days.
So at the moment when I do a Speed Test, my results are under 3000, before the 4th August outage I used to get over 4000 (around 4500 from what I remember).
I checked the link posted on Friday, and my exchange (Weymouth) is not in the list. Thoughts / input anyone?
18-08-2009 9:32 PM
