Downstream SNR varying wildly
- Downstream SNR varying wildly
Re: Downstream SNR varying wildly
29-02-2016 7:57 PM
If you are capturing the data on a laptop, you could try running the laptop on it's battery for a couple of hours in the daytime and apart from the TP-Link make sure all other equipment is turned off and power supplies unplugged from the mains - other Computers, Monitors, TV sets, Sky boxes, cordless phones, mobile phones, fluorescent lights including CFLs, other low voltage lights and equipment, anything that may have a Switch Mode PSU etc.
See if it makes any difference to the SNRM. If it does, switching things back on one at a time and watching the effect might identify any noisy equipment.
07-03-2016 10:01 PM
Quote 888 5688 888 5992 7.6 13.5 24.3 45.3 81 204 05:28:45
888 5688 888 5960 7.6 13.4 24.3 45.3 81 204 05:28:55
888 5688 888 5956 7.6 13.3 24.3 45.3 81 204 05:29:05
888 5688 888 5976 7.6 13.4 24.3 45.3 81 204 05:29:15
888 5688 888 5980 7.6 13.4 24.3 45.3 81 204 05:29:25
888 5688 888 5844 7.6 13.0 24.3 45.3 81 204 05:29:35
888 5688 888 5816 7.6 13.1 24.3 45.3 81 204 05:29:45
0 0 0 0 .0 .0 .0 .0 0 0 05:29:58
0 0 0 0 .0 .0 .0 .0 0 0 05:30:08
0 0 0 0 .0 .0 .0 .0 0 0 05:30:18
0 0 0 0 .0 .0 .0 .0 0 0 05:30:28
632 5664 888 5664 20.1 15.1 24.3 45.3 126 203 05:30:38
632 5664 888 5664 20.1 15.2 24.3 45.3 126 203 05:30:48
632 5664 888 5648 20.1 15.0 24.3 45.3 126 203 05:30:59
632 5664 888 5704 20.1 15.2 24.3 45.3 126 203 05:31:09
632 5664 888 5752 20.1 15.4 24.3 45.3 126 203 05:31:19
and the noise seconds etc:
Quote ~ # /firmware/dsl_cpe_pipe.sh pmcctg 0 0
nReturn=0 nChannel=0 nDirection=0 nElapsedTime=2086618 bValid=1 nCodeViolations=1150 nFEC=203624
~ # /firmware/dsl_cpe_pipe.sh pmlsctg 0
nReturn=0 nDirection=0 nElapsedTime=2086623 bValid=1 nES=59 nSES=2 nLOSS=1 nUAS=204 nLOFS=0
so since last time
nReturn=0 nChannel=0 nDirection=0 nElapsedTime=577981 bValid=1 nCodeViolations=478 nFEC=86479
nReturn=0 nDirection=0 nElapsedTime=577998 bValid=1 nES=104 nSES=2 nLOSS=2 nUAS=152 nLOFS=0
so can nES go backward? I thought it was number of errored seconds.
ANyway no idea why it went down, and came back up with slower upstream. I have yet to switch on 10s logging of the error seconds, and noise per tone. Hopefully get the chance to write the code soon.
07-03-2016 10:07 PM
10-03-2016 12:00 PM
The upstream data makes no sense:
Quote ~ # /firmware/dsl_cpe_pipe.sh g997sansg 0
nReturn=0 nDirection=0 nNumData=32 nFormat=nSnr(hex) nData="
00 00 00 00 00 00 00 00 00 00 00 00 D0 0D D0 0D D0 0D D0 0D D0 0D D0 0D D0 0D 50
16 70 12 00 11
E.g. what is going on with the D0 0D bits?
Edit: I've added bits per tone taken at the same time
11-03-2016 11:48 AM
Bit anyoying that I can't interpret the upstream SNR, oh well - c'est la vie.
11-03-2016 1:48 PM
11-03-2016 1:54 PM
Oh , just checked the logs:
Quote 632 5664 888 6200 20.1 14.0 24.3 45.3 126 203 08:43:56
632 0 888 0 20.1 .0 24.3 .0 126 0 08:44:06
0 0 0 0 .0 .0 .0 .0 0 0 08:44:16
0 0 0 0 .0 .0 .0 .0 0 0 08:44:26
0 0 0 0 .0 .0 .0 .0 0 0 08:44:39
0 0 0 0 .0 .0 .0 .0 0 0 08:44:49
888 5976 888 5976 7.7 15.1 24.3 45.2 74 204 08:44:59
So looks like it was a change in the noise margin, that went up to 15db. So definitly something not happy with my line.
11-03-2016 1:56 PM
1, Re-trains
2. Severe error seconds
3. Error Seconds
Also good to monitor
4 Snr
1 sample/min is sufficient
11-03-2016 2:00 PM
11-03-2016 2:01 PM
Harry: Currently logging US/DS current rate/maximum rate/SNR/attenuation and power - need to enable errors ..
11-03-2016 2:08 PM
11-03-2016 7:08 PM
Whats interesting now, is ppp goes down at times, while the ADSL2+ stays up! e.g:
Quote 8 2016-03-09 03:00:53 PPP Warning ppp0 LCP down
9 2016-03-09 03:00:53 PPP Error ppp0 LCP down
10 2016-03-09 03:00:34 PPP Error ppp0
11 2016-03-09 03:00:29 PPP Error ppp0 User request
12 2016-03-09 03:00:21 PPP Warning ppp0 LCP down
13 2016-03-09 03:00:21 PPP Error ppp0 LCP down
Quote 632 5664 888 5888 20.1 13.2 24.3 45.3 126 203 03:00:03
632 5664 888 5792 20.1 13.0 24.3 45.3 126 203 03:00:14
632 5664 888 5860 20.1 13.2 24.3 45.3 126 203 03:00:24
632 5664 888 5864 20.1 13.2 24.3 45.3 126 203 03:00:35
632 5664 888 5880 20.1 13.3 24.3 45.3 126 203 03:00:45
632 5664 888 5812 20.1 13.0 24.3 45.3 126 203 03:00:56
632 5664 888 5824 20.1 13.1 24.3 45.3 126 203 03:01:06
Now the ppp details I can only see through the log on http, need to see how to access ppp info from telnet.
12-03-2016 8:11 AM
Quote 1 2016-03-12 04:59:07 PPP Warning ppp0 LCP down
2 2016-03-12 04:59:07 PPP Error ppp0 LCP down
3 2016-03-12 04:58:19 PPP Error ppp0
4 2016-03-12 04:58:19 PPP Error ppp0 User request
5 2016-03-12 04:58:08 PPP Warning ppp0 LCP down
6 2016-03-12 04:58:08 PPP Error ppp0 LCP down
7 2016-03-12 04:58:08 PPP Error ppp0 User request
And this one did an adsl resyn as downsteam rate dropped to 632. I really am going to have to find time to write the code that processes error. A good hour last night poking round the telnet interface, and failed to find a way to log the ppp lcp messages...
12-03-2016 5:47 PM
Just to confirm, you are aware that PPP can drop without a loss of synch?
It is losses of synch that you really need to be concerned about here. Note also that a loss of synch, which resynchs at a different speed will lead to a drop of PPP at a later time when PlusNet updates their line profile. You might have seen posts around here of people being aware of an improvement in synch speed, but seeing no improvement is data speed tests - this is why, either the profile has not been updated, or the PPP session has not been refreshed to "adopt" the new profile.
Are you no closer to identifying the source of the REIN?
As Harry suggests (without reviewing the whole of the thread) has the line balance etc. been checked recently by faults?
12-03-2016 6:59 PM
