Downloading at a max of 118 KB/s
LJEDM
It has been like this for the past two days.
8 REPLIES 8
Oldjim
Resting Legend
Fixes: 63
Re: Downloading at a max of 118 KB/s
LJEDM
Here are screenshots of the speed and router statistics. I am also currently on hold with one of the worst customer service reps I have ever dealt with.
Oldjim
Resting Legend
Fixes: 63
As I assume that you are on 20CN (ADSL1) your IP profile is 1000kb/s so your speed isn't too far adrift Can you check the Plusnet Current Line Speed which, from memory, should be slightly less than that
Note that the 118kB/s reported in the first post is 944kb/s
LJEDM
Estimated line speed:1.0Mb (This may vary between 0.75Mb and 2.5Mb) - Checked on 2016-07-23 20:03:09
Current line speed:1 Mb
Although I am seeing nothing in the way of these speeds
Unfortunately not, that 118KB/s was the actual transfer speed I have been getting on direct downloads
Oldjim
Resting Legend
Fixes: 63
Slight confusion
118kB/s is 118 kilobytes per sec and equates to 944kb/s kilobits per second which is what the line speed is measured in
LJEDM
Ahh, my apologies. The main thing is that this speed has dropped dramatically and it now takes about 5 hours to download a 1.2gb file, when it used to take around 1 hour.
Oldjim
Resting Legend
Fixes: 63
1GB in 1 hour is about 278kB/s and you are getting 118kB/s so it should take about 2.4 hours
To achieve that speed (278kB/s) your sync speed must be at least 2848kb/s
That really isn't possible from your present line stats so something must have changed which has caused your noise margin to drop a lot
Can you try the quiet line test - dial 17070 option 2 and the line should be quiet
LJEDM
Thanks for your reply. I am not at home right now, but I was able to ring quiet line before leaving. There was some background static noise, but it wasn't too loud.
