Download speeds slower than guaranteed.
JohnLHolland
Hi there, I'm a long time customer to Plusnet and have been on the Unlimited Fibre package for many years and though the package used to offer faster download speeds before Plusnet downgraded it, it should still be giving a minimum of 36 Mb as per the current version of the package. Recently however I seem to be getting a much slower connection of around 22 Mb, which has been consistent for the last few weeks now.
I'm hoping I'll be able to resolve the issue here on the forums without having to contact support if possible, so any help is appreciated.
9 REPLIES 9
Fixes: 353
Re: Download speeds slower than guaranteed.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Fixes: 463
Moderator's note:
Thread moved from Full Fibre to Broadband
JohnLHolland
Thanks for the response. Is there any other way of doing a line test without a corded phone as I don't own one? That said, I would have thought it wasn't a phone line issue as the internet speed is consistent and stable, just slower than what I should be getting.
Fixes: 353
Which router do you have? Pity you done have a phone (at all?) as a line test is useful.
JohnLHolland
I have cordless handsets, so I can try doing a line test with that if it'll still do something at least. My router is the Plusnet Hub One.
Fixes: 353
OK,  that is useful - the original text I posted said a corded handset was preferable, not essential.
Can you also post this page from your Hub, obscuring your personal details?
JohnLHolland
Apologies for not reading your previous message properly. I've done the line test and there was no noise.
I've attached the info requested. Thanks.
Fixes: 353
Thanks for that information. If the phone was silent during the tests, please use the second link provided and report a broadband fault - from the Help Desk shot above, you have an Openreach network issue which requires investigation/rectification.
As well as the comment re Openreach, you are uploading masses of data, which will be impacting your download speed.
JohnLHolland
I do occasionally stream on Twitch as well as you use torrents, so I assumed that was what most of the upload data would be. I'll report an issue regardless, thanks for your responses.
