Download speeds less than 150kbps
- Download speeds less than 150kbps
- « Previous
- Next »
Re: Download speeds less than 150kbps
21-08-2009 7:28 PM
Cheers,
Jon
23-08-2009 8:23 PM
http://community.plus.net/forum/index.php/topic,77645.0.html
http://community.plus.net/forum/index.php/topic,78222.0.html
http://community.plus.net/forum/index.php/topic,77689.0.html
http://community.plus.net/forum/index.php/topic,77648.0.html
http://community.plus.net/forum/index.php/topic,77797.0.html
To be fair, i'm seeing some pretty good throughput (in the 4000-6000kps area) - but very, very sporadically. I don't expect anything near sync speeds 24/7, but with the bulk of downloads being under 2000kps, i think it's a pretty poor show.... Oh, that and and it's been 50 hours since I raised a problem ticket (#29763277 ) - and still no answer.
I've attached a of screenshot of D/L speed from http://www.mybroadbandspeed.co.uk/. (the BT speedtester seems to be knackered for most of today).
Any pointers/suggestions from you guys welcome!
Cheers,
Jon
23-08-2009 8:35 PM
23-08-2009 8:51 PM
I note on this link:
http://www.btwholesale-briefingportal.com/brief/view/4c71680687897e7e351321742b7a3c01
..BT refer to a "published WBC throughput Service Level Agreement (SLA)." Can we view this SLA anywere?
Cheers,
Jon
24-08-2009 2:15 PM
Have you tried rebooting recently? Or is it just sporadic fluctuation of speeds? Either way, a reboot wouldn't hurt.
24-08-2009 4:04 PM
Cheers,
Jon
03-09-2009 9:00 PM
As you can see, throughput drops below what i believe is the SLA for 21CN (400kps?) and the line is practically unusable between 18:00 and 20:00.
Given there are plenty of other posts on poor throughput:
http://community.plus.net/forum/index.php/topic,79107.0.html
http://community.plus.net/forum/index.php/topic,78968.0.html
http://community.plus.net/forum/index.php/topic,78782.16.html
...does this now suggest more of a global issue that PN can investigate?
04-09-2009 9:55 AM
We've seen general throughput issues which BT are aware of and there's a bunch of exchange upgrades ongoing which will hopefully improve things.
04-09-2009 10:41 AM
Is there a schedule for these exchange upgrades?
Cheers,
Jon
04-09-2009 10:46 AM
04-09-2009 5:33 PM
Quote from: jb5ep After logging some throughput stats (about 180 tests!) for a few days, it's clear that i'm seeing a significant drop in throughput only between 15:00 and 22:00 each day. The graph below shows the results of tests on 3 different speed testers, on a BRAS and PN profile of 5500 (the early stats were on a profile of 6500).
BT's aim on a 21CN connection on throughput speed is that if your sync rate is above 2Mbps (with a BRAS profile of 2000kbps or higher) then the throughput speed should be 2Mbps or higher (note that there will be overheads). If the sync rate is below 2Mbps then the throughput should be around the BRAS profile (again note the overheads).
Now, I'm concerned at the very least about the number of speed isues being seen. Some of course you can discount as being individual problems (wrong profiles for example) rather than related to something more global.
Recently we saw a capacity issue that hit a large number of exchanges, I'm wondering if some of the reports of speed are down to a similar problem where exchanges are hitting capacity. We've flagged this up to BT Wholesale to try and get a report on capacity and what flags they have for upgrading capacity, but in the mean time the best thing to do is raise faults and I'll ensure the faults guys raise them (note: throughput speed problems where the speed is the same all day will probably not be exchange capacity related, I'd expect the capacity related ones to be more noticeable at peak times).
Plusnet Technology
04-09-2009 5:43 PM
09-09-2009 6:19 PM
Keith doesn't think BT took any corrective action, although they may have done something like "reset the line card", which has sorted things.
Either way, i'll keep an eye on for a few more days - but for the time being, problem solved.
15-09-2009 7:28 PM
Over the last 7 to 10 days my throughput seems to have been pretty stable, generally meeting what I would expect from my profile. Now this change has occurred without any changes to my pc, phone line or router so I guess it must have been a BT issue all along. Other threads seem to imply that this is the case.
So, $64million question. What are Plusnet going to learn from the recent episodes of poor download throughput experienced by a number of trialists? For me the big lesson to learn is that Plusnet should not take at 100% verbatim the results of automated tests. Throughout my fault I was told on numerous occasions that the automated fault testing could not detect anything wrong with my connection and that the fault must lie at my end. Obviously that was not the case. So maybe the automated test systems need to be reviewed.
On a different note. Having just checked my router I have noticed that for some reason my connection has switched from fast to interleaved. Why would this happen and do I need it interleaved? It has been working fine as fast.
Best
Kevin
16-09-2009 8:37 AM
Glad to see yours is sorted,only took 2 months,I also had your problems, and it did not matter what
proof I supplied that my end was fine,it was ignored at Plusnets end!
To the point where I gave up and quit,
I now have the best speed I've seen in years
Today 08:20 6853 kbps (857kB/s) 379 kbps (47.4kB/s)
This is with the same line same kit etc,
ADSL Link
Downstream
Upstream
Connection Speed
8128 kbps
448 kbps
Line Attenuation
38.0 db
24.0 db
Noise Margin
7.8 db
19.0 db
This is on there Access plan,8meg max
On the 21st I am going over to their ADSL2 network and can't wait,
This is I move I was forced into by lack of support,I had been here for 5 years odd
and remember the good days,Alas no more BT in control you see.
Later
- « Previous
- Next »
