Download speeds dropping over past week ???
tailendcharlie
My normal d/l speed has been over 2.0 MB/s. It dropped to 1.9 MB/s for a while, no big deal.
Now it's down to 1.67 MB/s. Nothing has changed with hardware or software here.
I wonder if someone can review my line please ?Huh
tailendcharlie
Re: Download speeds dropping over past week ???
Further test result...
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi tailendcharlie,
Your speeds appear to have returned to normal, from the latest test?
Chris Pettitt
Cloud Environments Engineer
tailendcharlie
Hi Chris, No, not normal. Maybe I've been lucky up till now, but a drop of 15% is noticeable with bigger downloads.
I'm in a rural area so contention shouldn't be an issue. I have noticed BT Open reach vans working in the area over the past 2-3 weeks...
Anything obvious at your end ?Huh
Thanks, Rob.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi Rob,
I can't spot anything obvious from this end. There is some Planned Maintenance tonight by BT Openreach; they are doing some hardware/software updates.
With regards to the speeds; given the length of your line, we'd expect speeds a little better, around 16-17Mb. You mentioned download speeds of around 2.0 MB/s which leads me to believe that you've had speeds of around 19Mb I would think.
Would you be able to connect to your Test Socket so we can take another look? I know nothing has changed internally, but it's something we can at least rule out.
Chris Pettitt
tailendcharlie
OK. Now connected to the test socket with a new filter. Powered down the router at the same time and rebooted.
Still no change....
Plusnet Staff
Plusnet Staff
Fixes: 5
The only thing I can do remotely, is to move your SNR Target from 6db down to 3db to try and increase your sync rate.
If I do this though, there is a chance your line could become intermittent, and it would make it more susceptible to an intermittent issue.
Chris Pettitt
tailendcharlie
Thanks Chris. I'll wait a while and see if anything changes..
I'll be back to report  Smiley
