Download speeds down by half lately
- Re: Download speeds down by half lately
26-07-2014 8:18 AM
I am on ADSL2+ and normally get about 12.8 Mb/s download regularly. Last couple of days its below 6Mb/s on various test sites, including BT. My IP profile is 13.97Mb/s Upload speed is normal at about 1Mb/s. All other router stats are normal. I am on Telehouse West gateway ptw-ag04.
Anyone else getting poor results !
Message 1 of 4
(811 Views)
3 REPLIES 3
26-07-2014 12:40 PM
Check your Current Line Speed (log-in required).
If you have had a low synch event which has then corrected itself, the Current Line Speed can sometimes take a while to catch up, or even get stuck.
Message 2 of 4
(473 Views)
26-07-2014 1:20 PM
Hi Dabow,
I've checked your line and everything appears fine (A few errors but not enough to affect the speed that much). I recommend you simply reboot your router and if you continue to have problems please post us your BT Wholesale speedtest result and we'll investigate further.
Message 3 of 4
(473 Views)
27-07-2014 8:23 AM
Thanks for the checks LukeS. Have carried out a re-boot and things seem to be back to normal. All speed check sites give the same result of about 13Mb/s download which is normal for me. Thanks all for the advice.
Message 4 of 4
(473 Views)
