Download speed
atbs1
Download speed
Just downloading Google Earth a 12.8Mb file. It is very slow to download and my speed is 3365, currently the download time remaining is 54minutes. My account is not being throttled.
Any one any ideas why it's so slow please?
paulby
Re: Download speed
Your download speed can also be affected by the server you're downloading from.  If it's busy or has a problem your speed will be affected.
Re: Download speed
Remote servers often have to share the bandwidth they have with 1000s of connections which means slowdowns will occur when it is very busy (i.e. lots of connections).
There can also be bottle necks between the remote server and you also causing slowdowns.
If a local speed test shows your connection is working normally then that proves it's not you.
atbs1
Re: Download speed
Ok, thanks Peter - i'll keep a general eye open on the d/l speeds.
