Download speed seems ok, but upload speed seems woeful
- Re: Download speed seems ok, but upload speed seem...
16-11-2012 12:46 PM
Hi
First post
Im getting the occasional connection drops, but im more concerned about my upload speed which is never more than around 0.12 mbps, im hoping that i can get that increased
Here is a recent speedtest, and my thomson tg 585 v8 router stats
Thanks Mark
Link Information
Uptime:
0 days, 0:41:18
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,224 / 7,840
448 / 7,648
Data Transferred (Sent/Received) [kB/MB]:
0.00 / 159.88
Output Power (Up/Down) [dBm]:
12.0 / 17.5
Line Attenuation (Up/Down) [dB]:
4.5 / 13.5
SN Margin (Up/Down) [dB]:
29.0 / 13.0
Vendor ID (Local/Remote):
TMMB / TSTC
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
Error Seconds (Local/Remote):
0 / 0
FEC Errors (Up/Down):
0 / 61
CRC Errors (Up/Down):
0 / 0
HEC Errors (Up/Down):
0 / 0
First post
Thanks Mark
Link Information
Uptime:
0 days, 0:41:18
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
1,224 / 7,840
448 / 7,648
0.00 / 159.88
12.0 / 17.5
4.5 / 13.5
29.0 / 13.0
TMMB / TSTC
0 / 0
0 / 0
0 / 0
0
0 / 0
0 / 61
0 / 0
0 / 0
Message 1 of 9
(1,474 Views)
8 REPLIES 8
Re: Download speed seems ok, but upload speed seems woeful
16-11-2012 12:51 PM
are you connected wired or wireless and what is the computer operating system
Message 2 of 9
(871 Views)
16-11-2012 3:30 PM
Hi
Windows 7 64bit and yes wireless
Message 3 of 9
(871 Views)
16-11-2012 3:32 PM
Can you try a wired test to confirm it is the wireless that is causing the issue.
See also http://community.plus.net/forum/index.php/topic,92497.0.html
Message 4 of 9
(871 Views)
18-11-2012 11:14 AM
Quote from: jelv Can you try a wired test to confirm it is the wireless that is causing the issue.
Thankyou, but i cant easily test a wired connection without moving alot of things, as the main (and only) telephone socket comes into the front of our house in our bedroom, whee as out pc is in a back bedroom and my ps3 is downstairs.
Would it be advisable to update the firmware on my thomson router?? as its a year old.
Also i have a 5-6 year old netgear router, would it be worth me trying that instead??? would the speeds of that my comparable ?
Thanks Mark
Message 5 of 9
(871 Views)
18-11-2012 4:56 PM
Definitely try the Netgear providing it is ADSL2 compatible and it probably is
Message 6 of 9
(871 Views)
19-11-2012 11:43 AM
Hi fergusont20,
Did you manage to try the Netgear router or a wired test.
Everything on your line appears to be fine after inspecting it.
Chris
Chris
Message 7 of 9
(871 Views)
22-11-2012 12:32 PM
Hi
Unfortunantly i can only find my netgear router and not the power lead. and i cant try a wired test, as my very long ethernet cable is gone missing.
My Thomson router tg 585 v8 is omn firmware 8.2.7.8, is this the latest version?? if not how do i update it?
Thanks again
Thanks again
Message 8 of 9
(871 Views)
22-11-2012 12:55 PM
20 Metre CAT 5e cables for around £2.
http://www.ebay.co.uk/itm/20M-CAT5e-Cat-5e-RJ45-ETHERNET-LAN-NETWORK-PATCH-LEAD-CABLE-/110936663457?...
http://www.amazon.co.uk/gp/product/B000IT5PNA/ref=nosim/?tag=hotukdeals-21
Hope it helps and you can resolve your problem.
Has anyone seen my signature, it's gone missing.
Message 9 of 9
(871 Views)
