Download speed only 60k a sec with new plusnet hub2 have had to use my old router to get any speed
krieghoff
My download speed has suddenly gone to old copper speed, and I've had to go back to using my old Billion router.
1 REPLY 1
Fixes: 306
Re: Download speed only 60k a sec with new plusnet hub2 have had to use my old router to get any spe
A little more information would be helpful. Using the Hub2, the following would be helpful:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
