Download speed now stuck at 0.23mbps :-(
- Re: Download speed now stuck at 0.23mbps :-(
11-04-2014 2:08 PM
Hi all,
My broadband connection just reset about 40 mins ago.
Reconnected at 6900 but now downloads have gone from 5.3 meg to 0.23 meg!!
The upload speed was not affected.
The SNR was 6.1dB which is about normal.
Any ideas?
Just popping out so I've disconnected the router and ADSL cable. Phone line works fine with no crackles.
Can someone have a look at my connection and also advise if capling my upload speed will increase my downloads?
Any ideas?
Message 1 of 7
(2,551 Views)
6 REPLIES 6
11-04-2014 3:14 PM
Hi Damian78,
I'm sorry to hear of the issues that you're having here.
I'd be more than happy to take a look at your line, however as it's now disconnected, I won't be able to test your line. Once you've reconnected it, if you could let us know, and we'll take a look for you.
Message 2 of 7
(1,890 Views)
11-04-2014 3:22 PM
I've reconnected it and switched on now.
Message 3 of 7
(1,890 Views)
11-04-2014 3:33 PM
I've just checked your line over and can see that you've reconnected at speeds of 6937 which seems fine for your line.
Your speed profile is set correctly too. Can you please visit http://speedtest.btwholesale.com and run the initial speed test followed by 'Further Diagnostics'?
This will give us a good indication of where the fault may lay.
Message 4 of 7
(1,890 Views)
11-04-2014 3:53 PM
1. Best Effort Test: -provides background information.
Download Speed
5.42 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.42 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.12 Mbps
Upload Speed
0.81 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.81Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Hmmmm....not sure what's going on now
Download Speed
5.42 Mbps
0 Mbps 7.15 Mbps
Upload Speed
0.81 Mbps
0 Mbps 0.83 Mbps
Message 5 of 7
(1,890 Views)
11-04-2014 3:56 PM
http://www.speedtest.net/my-result/3432655603
I tried the Speedtest App on my iPhone 5 and thas showing 0.23 so maybe my connection is fine?
Message 6 of 7
(1,890 Views)
11-04-2014 4:03 PM
The connection looks fine, you can lose quite a lot of speed via Wireless.
It's always a good idea to try with an Ethernet on a PC/Laptop/Mac to see how your line is operating.
Message 7 of 7
(1,890 Views)
