Download speed issues
- Download speed issues
01-03-2011 9:38 AM
BT Line check
Download speedachieved during the test was - 857 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :5696 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
Re: Download speed issues
01-03-2011 11:53 AM
Not entirely sure what's going on but it looks like your profile seems to be going crazy at the exchange on the 26th of each month... I've just run a consistency check (that is, checking your line profile across the DSLAM and BRAS in the exchange) and it's come up as failed so I've done a bit of maintenance as well - within the next hour or so things should start to sort themselves out.
Hope that helps, please let us know if it doesn't.
02-03-2011 7:11 AM
I'll watch out to see anything happens with it again on the 26th of this month and let you know if so.
Thanks for your help.
26-03-2011 7:54 AM
Just got home from work this morning and things have indeed gone crazy again right on the 26th. Everything was fine when i left for work last night, now on speedtests i'm getting results of 0.2mbps.
This is painful.
28-03-2011 11:21 AM
It looks like we can put an order through to move you to 21CN if you like - that should move you to different exchange kit and hopefully stop this from happening. Other option is to leave you on 20CN and reset the SNR as happened last month, then we can look at possible causes for this. Our suspicion is that it's REIN, electrical interference basically from something that happens on the 26th each month either near your premises or the exchange. Do you know if anyone else in your area has the same issues on the same day?
Either way please let us know how you'd like to proceed and we'll get on it for you.
28-03-2011 1:36 PM
28-03-2011 2:57 PM
06-04-2011 5:07 PM
06-04-2011 7:22 PM
07-04-2011 4:18 PM
26-05-2011 8:54 AM
Also recently i've been having issues with my connection cutting out for a few minutes every time someone answers the phone. Any ideas?
26-05-2011 10:58 AM
I've been looking into this and doubt it's anything to do with the date. You can see form the graph that there's quite a bit of a dropping connection which has dropped your speed, so I'd firstly look here to troubleshoot and raise a fault if necessary.
Jojo
14-06-2011 11:02 PM
Could this means that there is prehaps and issue with the wiring in my house?
15-06-2011 7:17 AM
15-06-2011 11:38 AM
Any telephone equipment must have a filter attached to it or it will cut off the broadband every time it's used.
Jojo
