Download speed dropped to half but Plusnet says that's OK
- Re: Download speed dropped to half but Plusnet say...
03-12-2015 9:45 PM
Re: Download speed dropped to half but Plusnet says that's OK
04-12-2015 2:49 PM
Quote Download speed dropped to half but Plusnet says that's OK
Have we? I've checked your account and can see we've raised a fault today for you after you came through on web chat.
I have noticed straight away that it's an authentication fault but I can't see that we've been looking at any speed issues for you. Apologies if this was perhaps discussed over the phone or chat but not noted!
I can see from your connection logs that we did see attempts to connect coming through last night. However the router was presenting the wrong password. The last one we see recorded is at 19:32.
I'd advise logging into the router and updating the password to get reconnected first then reply back here so we can start to look into the speed issue.
Given what you've said about the changes to the line I have run a copper line test which passed showing no issues, as we don't provide the line this means we're not able to get detailed tests relating to the line itself so I;'d also advise doing a quiet line test by dialling 17070 in the meantime.
04-12-2015 11:36 PM
The main problem is that my line speed dropped from 10mbps to 4.7mbps four weeks ago when the physical line was interfered with by window fitters. All I want is for BT to come and repair the cable. 4.7mbps may be acceptable for my line, but I've been accustomed to 10mbps for years and I can no longer stream video, so I feel I'm not getting the best out of my internet connection.
05-12-2015 9:43 AM
Quote from: _Adam_Walker_ as we don't provide the line
I think this probably means you will need to contact your phone provider to get the line fixed.
05-12-2015 11:41 AM
05-12-2015 1:06 PM
To be is to do - Kant
do be do be do - Sinatra
05-12-2015 1:08 PM
05-12-2015 1:11 PM
11-12-2015 11:15 AM
11-12-2015 4:47 PM
I can see how fixing and authentication issue would start a new PPP session which might apply a revised IP profile to the line, thereby changing the DATA transfer rate. However whilst there was a PPP authentication issue, it would not be possible to determine the DATA transfer speed.
12-12-2015 9:46 PM
