Download or Upload
- Re: Download or Upload
Download or Upload
14-05-2013 5:17 PM
14-05-2013 6:35 PM
15-05-2013 6:02 PM
THOMSON
Thomson Gateway
Broadband Connection
DSL Connection
Internet Services
Toolbox
Home Network
[ Administrator ] Overview | Details | Help
Home > Broadband Connection > DSL Connection
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 0 days, 0:19:44
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,176 / 11,131
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 12.0 / 29.5
SN Margin (Up/Down) [dB]: 6.0 / 3.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 288
HEC Errors (Up/Down): 0 / 266
Pick a task...
See information about my broadband connection(s)
I hope this is the information that is needed for your help as a elderly gent I am not very good with this copy and paste so I hope all I have done is correct.Thank You
15-05-2013 6:34 PM
Your Upstream sync speed is fine, but although your downstream is fairly fast it should be better, but IIRC you have some internal wiring that could do with sorting but you didn't feel able to have a go at it. The downstream speed is usually the most important for normal usage and as you are probably are the only user it should be fast enough for what you may be running at any one time.
Post back if you have any more questions.
15-05-2013 8:07 PM
16-05-2013 12:13 PM
17-05-2013 5:49 PM
17-05-2013 6:07 PM
17-05-2013 6:34 PM
17-05-2013 6:55 PM
17-05-2013 11:30 PM
18-05-2013 1:10 AM
18-05-2013 8:52 AM
Hth
18-05-2013 3:37 PM
