Download dropped to 1.58Mbps
pdc95
Hi
My download speed has dropped to 1.58Mbps from 11.2Mbps.
                            Down              Up
S/N                      28                    58
Atten                    315                  176
Attanable            16536              1164        Kbps
Rate                    15150              1176      Kbps
Help !!!!!!!!
Pete
Fixes: 46
Re: Download dropped to 1.58Mbps
A diagnostic test shows me a synch speed of 15150kbps for your line at present, your connection looks fairly stable to so I can't see an obvious reason I'm afraid.
I'm going to advise rebooting your router first then log a <a href="http://faults.plus.net">fault</a> if nothing's changed.
 Adam Walker
pdc95
Hi
That fixed it
Many thanks
Pete
Fixes: 46
No problem, we'd usually advise trying a reboot as the first port of call when encountering a problem like that.
 Adam Walker
