Download Speed
AMX
Download Speed
Download speed seems stuck, can anyone help.
1. Best Effort Test:  -provides background information.
Download  Speed
1.77 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.77 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.31 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.34 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.34Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Router Stats.
xxxxxxxxxxx
IP Address: 146.199.129.7
Subnet Mask: 255.255.255.255
Default Gateway: 195.166.130.177
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
Host Name:
Domain:
MAC Address: --:--:--:--:--:--
MTU: 1500
DSL Details
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 2617 kbs 431 kbs
Max Rate: 2813 kbs 796 kbs
Noise Margin: 7.4 dB 16.7 dB
Attenuation: 60.8 dB 36.0 dB
Output Power: 17.0 dBm 12.3 dBm
Protocol: G.DMT2 Annex A
Channel: Fast
DSLAM Vendor Information Country: {46336} Vendor: {IFTN} Specific: {51313 }
ATM PVC: 0/38
Rate Cap: 2813 kbs
Attenuation @ 300kHz: 60.8 dB
Uncanceled Echo: -22.1 dB Ok
VCXO Frequency Offset: 2.2 ppm Ok
Final Receive Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 22833438 178326 0 0
Receive: 265146509 245091 0 0
ATM Traffic Cells Errors %
Transmit: 42338468 0 0
Receive: 528394893 0 0
DSL Link Errors
Collected for 46Days23:29:44
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 416203 57505 861 0:00:36
Loss of cell Delineation 12592 495 17 0:02:33
DSL
Link Retrains: 5 0 0 1Day14:10:49
DSL Training Errors: 6 0 0 1Day14:10:28
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 24 0 0 1Day8:11:39
Loss of Signal Failures: 8 0 0 1Day14:10:50
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 8 0 0 1Day14:10:50
Cum. Seconds w/Errors: 181414 14472 272 0:00:36
Cum. Sec. w/Severe Errors: 19595 3544 86 0:02:49
Corrected Blocks: 3353350 0 0 31Days5:30:22
Uncorrectable Blocks: 1124516 173663 3425 0:00:36
DSL Unavailable Seconds: 266 0 0 1Day14:10:10
thanks
Fixes: 162
Re: Download Speed
You should have a profile of 2300 based on that sync rate (2617 kbs). I've just updated it on our side, can you log in to the router and hit 'disconnect' and then 'connect'.
 Chris Parr
 Plusnet Staff
AMX
Re: Download Speed
Hi Chris,
        Thanks for your prompt help,all good again now.
              regards
