Download Speed suddenly dropped.
- Re: Download Speed suddenly dropped.
30-08-2013 7:58 AM
I moved to Plusnet from MAAF exactly one month ago. After initial speed problems( that were sorted out by Adam updating my Plusnet IP profile) all has been going well with download speeds around 12 Mbps and upload around .8Mbps as they had always been with MAAF.
On Wednesday my download speed dropped to 8.5Mbps and has stayed there since. Upload speed is still OK.
I have tried different gateways and another computer with the same results.
I have checked my BT IP Profile and that .s still at 12.98 Mbps.
Would someone at Plusnet check that my Plusnet profile is still OK. If it is, any suggestions as to what I can do to get the speed back?
Thanks, robski1
Thanks, robski1
Message 1 of 9
(2,908 Views)
8 REPLIES 8
30-08-2013 10:25 AM
You can check your own Current Line Speed (Plusnet profile).
Message 2 of 9
(773 Views)
30-08-2013 10:46 AM
Hi Brian,
I have just checked and it says current line speed is 9.2. This was 12.9 when I checked last week.
A significant drop in a few days. Any ideas how to get back to where it was?
Regards, Rob.
Regards, Rob.
Message 3 of 9
(773 Views)
30-08-2013 10:59 AM
Hi Strat,
Carried out BT test and got the following results: Download 8.71Mbps, Upload .94Mbps, IP Profile 12.98Mbps.
Where do I go from here?
Best Regards, Rob.
Best Regards, Rob.
Message 4 of 9
(773 Views)
30-08-2013 11:19 AM
Plusnet should be able to bump your 'current line speed' back up to 12.9 to match the BT IP profile, that should help.
Call me 'w23'
Message 5 of 9
(773 Views)
30-08-2013 11:42 AM
I've manually changed your profile so you should now see that your speed has increased.
Message 6 of 9
(773 Views)
30-08-2013 11:50 AM
Thanks Chris, everything back to normal.
Any ideas why the profile would have dropped at your end?
Thanks again,
Rob.
Thanks again,
Rob.
Message 7 of 9
(773 Views)
30-08-2013 1:07 PM
We received a delta report on the 28th to drop your line speed. It must have very briefly dropped.
Message 8 of 9
(773 Views)
30-08-2013 1:14 PM
Thanks Chris.
Message 9 of 9
(773 Views)
