Download Speed Problums
DreamVB
Been with plusnet a long time now, and has been fine, but the last few weeks the speed has seemed to be slipping and also I noticed things in my account differnet first one is, I cannot view usage anymore just says there no information to it I also looked for my Estimated line speed and it just gave this message
Current line speed:
    19.4 Mb
I done a speed test and got this back.
Latency 24ms
Jitter 2ms
Download Speed 9.17Mbps
Upload Speed 0.95Mbps
I also looked in my router and got some stats I duno what most of it means so Maybe something gone wrong with my router not sure.
System Up Time 74:23:45
Port 	Status 	TxPkts 	RxPkts 	Collisions 	Tx B/s 	Rx B/s 	Up Time
WAN 	PPPoA 	5063188 	6606421 	0 	1474 	812 	74:22:15
LAN1 	Link down 	-- 	-- 	-- 	-- 	-- 	--
LAN2 	Link down
LAN3 	Link down
LAN4 	Link down
WLAN b/g/n 	300M 	5703251 	4327440 	0 	11875 	1585 	74:22:56
WLAN a/n 	300M 	1167856 	826042 	0 	5832 	261 	74:22:50
ADSL Link 	Downstream 	Upstream
Link Rate 	22191 Kbps 	1134 Kbps
Line Attenuation 	6.0 dB 	3.3 dB
Noise Margin 	2.3 dB 	5.1 dB
Thanks.
DreamVB
Re: Download Speed Problums
Just a recap from yesterday My speed has gone right down even pages are takeing ages to load.
My speed report now.
245 ms	3.19 Mb/s	1.74 Mb/s
INFONET Services Corporation
I think the root of my problums is something to do with this
ever since I been connecting to this I had problums and I tryed resetting my router about 20 times and just get the same thing and connecting getting to be a bit of a joke now. and it seems loads of people in the forum with the same connection speed issues anything been done about this problum?
Fixes: 65
Hi there DreamVB,
I've just checked your account and can view your usage fine so I suspect it should be visible to yourself too, let me know if that's still a problem though.
The downstream estimate for your line is 19mbs and your line seems to be syncing slightly above that so I think you're looking at a WiFi issue assuming that's how your devices connect. If that's the case do try following the steps here and let us know how you get on
https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
 Adam Walker
DreamVB
Thanks Adam speed seems to be a lot better now, o thanks for letting me know about the Usage I llook at the link you give for the ifi problums to, Thanks again.
