Download Speed Again
- Download Speed Again
02-02-2009 8:44 PM
I'm on up to 8 meg and normally get around 4.5 meg.
DSL Connection Details
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT Annex A
Downstream Rate: 5888 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 6.0 dB (Downstream), 23.0 db (Upstream)
Current Attenuation: 43.2 dB (Downstream), 28.0 db (Upstream)
Current Output Power: 19.7 dB (Downstream), 11.9 db (Upstream)
DSLAM Vendor Information: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
PVC Info: 0/38
Internet Connection Details
Connection Type: PPPoA
Username: *****
Internet Address: ******
Subnet Mask: 255.255.255.255
Default Gateway: 195.166.128.64
Primary Domain Name Server: 212.159.6.9
Secondary Domain Name Server: 212.159.6.10
Domain:
Maximum Transmission Unit (MTU): 1500
Gateway Ping: Successful
DNS Communication: Successful
Configuration Server Post: Waiting for DNS information
jim:blue personally identifiable information removed mod:end
Re: Download Speed Again
02-02-2009 8:54 PM
Just looking at the ticket in question and it does appear that you do have quite good line stats so I can see why my colleague could not find a fault with your line. Have you done any BT speed tests at http://www.speedtester.bt.com at all? If not, do a couple of them and pop the results back on the ticket. We can then see the actual throughput you are getting as at the moment your slow speeds could be down to either the wireless connection (ethernet provides higher download speeds), random test result, internet traffic, contention in peak times etc so it is also worth going through the advice on the ticket.
If you have done those tests and checked everything out, give us a shout and hopefully we can sort it for you.
02-02-2009 10:10 PM
03-02-2009 3:00 PM
No LLU or cable in my area.
03-02-2009 3:02 PM
03-02-2009 4:07 PM
03-02-2009 4:17 PM
Have up your exchange here to see if anyone other than BT Wholesale is in. If not - your stuck, no point changing ISP
http://www.samknows.com/broadband/search.php
04-02-2009 12:26 AM
Quote No LLU or cable in my area.
04-02-2009 2:40 PM
04-02-2009 2:42 PM
04-02-2009 2:44 PM
Quote from: Mick4545 LLU provider.
Which one(s)?
Honest opinions await........
04-02-2009 2:54 PM
04-02-2009 3:13 PM
04-02-2009 3:23 PM
04-02-2009 6:25 PM
