Down Load Speed/upload Speed and in game ping problem
- Down Load Speed/upload Speed and in game ping prob...
Re: Down Load Speed/upload Speed and in game ping problem
16-01-2014 11:46 AM
16-01-2014 3:35 PM
16-01-2014 4:16 PM
New stats after nearly 6 hours, last one was after a reset and 6 minutes up time, sorry if you got the wrong idea about it.
Uptime: 0 days, 5:05:12
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 768 / 4,224
Data Transferred (Sent/Received) [MB/GB]: 120.90 / 2.74
Output Power (Up/Down) [dBm]: 12.5 / 18.7
Line Attenuation (Up/Down) [dB]: 31.5 / 49.5
SN Margin (Up/Down) [dB]: 11.0 / 9.3
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 25 / -
FEC Errors (Up/Down): 89 / 62,132
CRC Errors (Up/Down): 2 / 80
HEC Errors (Up/Down): - / 847
On a side note I have noticed my in game ping to go up and down which is being caused by other people using the connection like web browsing, youtube and downloads, is this a router QOS problem or a side affect of plusnet prioritisation or some thing completely different.
I am happy to report though that my connection is alot better then on O2, webpages load faster, quicker downloads with youtube at 720p and some websites that where blocked before I can now access again.
17-01-2014 9:34 AM
Looking at those stats I'm worried about the number of errors in a 5 hour uptime, I'm not sure it'd train at a faster speed to be honest as I'd worry about reducing that target SNR. Sorry about that.
As for the ping, it'll be increasing because those services are using the router's upload - not the download. We can't QoS that I'm afraid, though you might be able to set some rules up there to prioritise packets from your own PC? Don't tell them if you do though
I think npr has some information on that on his site here: http://npr.me.uk/ipqos.html
Hope that helps.
17-01-2014 11:05 AM
Here my errors after 24 hours
FEC Errors (Up/Down): 207 / 229,760
CRC Errors (Up/Down): 4 / 262
HEC Errors (Up/Down): - / 2,324
is there any thing I can do about the errors or is it just how it is with BT connections and copper lines ?
On another thought would a move to adsl2/2+ be any good or would I be in the same boat because I know they use the same frequencies and better modulation and better error handling.
17-01-2014 11:34 AM
Uptime: 0 days, 0:01:41
Bandwidth (Up/Down) [kbps/kbps]: 768 / 3,200
Data Transferred (Sent/Received) [kB/MB]: 366.72 / 1.11
Output Power (Up/Down) [dBm]: 12.5 / 18.0
Line Attenuation (Up/Down) [dB]: 31.0 / 49.0
SN Margin (Up/Down) [dB]: 11.0 / 9.4
I have restarted it a few times now to see if it would go back up and no, it just goes lower.
On another note this damm router (582n) can't seem to remember my settings in the interface like in wifi or toolbox keeps going back to default, it stores my settings but then after a restart it goes back to default
17-01-2014 12:11 PM
Quote from: ONeill I have restarted it a few times now to see if it would go back up and no, it just goes lower.
If the exchange sees a number of disconnections it thinks it's because of a problem with the line and it raises the target noise margin which will lower the speed in an attempt to stabilise the line.
You should therefore only ever do ONE restart to see if it improves things. Your target is still 9 so it looks like you might have got away with it - this time.
17-01-2014 12:46 PM
I don't know whats happening with the router/line or the exchange but it seems it's creeping back up again
Bandwidth (Up/Down) [kbps/kbps]: 736 / 3,424
Data Transferred (Sent/Received) [MB/MB]: 1.34 / 11.42
SN Margin (Up/Down) [dB]: 11.0 / 9.7
Error Seconds (Local/Remote): 3 / -
FEC Errors (Up/Down): 2 / 81
CRC Errors (Up/Down): 0 / 4
17-01-2014 3:23 PM
He said he was going to send me a link so I can do my own speed tests over 72 hours and report back to them, not had an email yet with the link but does he mean the one on my portal or the BT performance test?
17-01-2014 4:15 PM
You can either use speedtest.net (link in my signature) or better http://www.thinkbroadband.com/speedtest.html
17-01-2014 6:04 PM
17-01-2014 6:19 PM
20-01-2014 11:06 AM
Router has been up for 3 days nearly and it's still syncing at the same speed 3424, is it now worth a router restart to get it to sync higher or ask for a SNR reset ?
Interleaving is on so I am told if that matters also still confused why I an some other people I've been reading are on ADSL1 when our exchange is ADSL2+ enabled?
Uptime: 2 days, 21:02:04
Data Transferred (Sent/Received) [MB/GB]: 440.53 / 9.54
Output Power (Up/Down) [dBm]: 12.5 / 18.1
SN Margin (Up/Down) [dB]: 11.0 / 14.8
Error Seconds (Local/Remote): 200 / -
FEC Errors (Up/Down): 325 / 104,345
CRC Errors (Up/Down): 13 / 257
HEC Errors (Up/Down): - / 998
20-01-2014 11:55 AM
If your line is stable the next step is a SNR reset which Plusnet have to request. They will want to see the line is stable before requesting that (i.e. no resyncs)
21CN is not just ADSL2+, it is ADSL1 or ADSL2 or ADSL2+ depending on which works best for the individual line.
20-01-2014 12:49 PM
Also can a member of plusnet do a SNR reset for me please ?.
