Domain names and email addresses
- Domain names and email addresses
07-10-2007 10:10 PM
Hi All,
When it comes to the domain names hosted on Plusnet, how do I set up the email address for it? I tried to create a new mailbox but it doesn't want to create it using the specified domain name.
Message 1 of 2
(1,182 Views)
1 REPLY 1
Re: Domain names and email addresses
07-10-2007 10:27 PM
Hi hektorshouse,
If you have a domain hosted with us then whatever mailboxes, aliases etc. you have set up for your PlusNet email will be mirrored for your domain. When you set up a new mailbox you only need enter the bit before the @ sign and it'll automatically set it up for any domains you have as well as your PlusNet one.
For example if I have a PlusNet mailbox called paula I will be able to collect email sent to paula@paula.plus.com and my hosted domain, paula@paula.co.uk, through the same mailbox. The same goes for alias email addresses that are delivered to that mailbox.
Does that make sense? Basically, anything you do in your email settings will be the same for PlusNet and any other domains (except where you are offered a choice of domains to apply a setting to, Spam for example)
Hope that helps! PM me if you need further clarification
Message 2 of 2
(353 Views)
