Does you does or does you don't have fibre?
- Re: Does you does or does you don't have fibre?
12-04-2012 8:59 PM
BT system reports this:
Your cabinet is planned to have WBC FTTC by 30th September 2012. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 28.1Mbps and upstream line speed of 5.8Mbps
If my line currently supports fibre do i have it or will i have to wait.
Message 1 of 9
(1,591 Views)
8 REPLIES 8
12-04-2012 9:08 PM
You cant have it until your Cab is enabled. Your line supports fibre, when it becomes available.
M
M
Message 2 of 9
(657 Views)
12-04-2012 9:10 PM
Do you not think that, possibly, the wording could be a bit less unclear ?
Call me 'w23'
Message 3 of 9
(657 Views)
12-04-2012 9:15 PM
Clear as mud.
When BT enable cabinets do they tend to do it early if so is it generally only early by days or is it a few weeks?
Message 4 of 9
(657 Views)
12-04-2012 9:38 PM
I cant honestly remember one being done early. The reverse is more the norm going by current trends, unfortunately.
Message 5 of 9
(657 Views)
12-04-2012 9:42 PM
maybe for Christmas then
Message 6 of 9
(657 Views)
12-04-2012 10:23 PM
Confusion yes see my previous post.
http://community.plus.net/forum/index.php/topic,103890.0.html
Message 7 of 9
(657 Views)
13-04-2012 12:22 PM
I did also wonder as mine now says, as of today...
It also says...
The main difference between the two is 'currently supports' and 'could support'.
Quote Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 71.3Mbps and upstream line speed of 20Mbps.
It also says...
Quote Your exchange is planned to have ADSL2+ by 31st August 2012. Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 14Mbps; typically the line speed would range between 8Mbps and 18.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 14Mbps; typically the downstream speed would range between 8Mbps and 18.5Mbps.
Message 8 of 9
(657 Views)
13-04-2012 4:31 PM
Don't forget the 30th September is a place holder date, so they don't currently know for sure when it will be. I'd just keep checking it from time to time
Message 9 of 9
(657 Views)
