Does sending HELP to 07800 008121 Do anything?
Fixes: 303
Re: Does sending HELP to 07800 008121 Do anything?
@James30  - are you 100% sure of that?
Azagoth
James30
Fixes: 32
@jab1  - After finding it on our website I'm not sure at all now, I've found this on our website @ https://www.plus.net/help/report-a-problem/broadband/ so I've passed on that people aren't getting a response back from it incase there's an issue.
James - Plusnet Sheffield
Phaeton
I beg to differ (currently), 1 month later & I'm still awaiting a response
Fixes: 303
Fair enough @James30 . I only queried your statement as , AIUI, that number and its associated action, is to determine, automatically, if a subscriber has an issue, based on automated tests. Unfortunately, those tests on occasion, return false positive/negative results, which is why, when I point customers to the links, I ask them to report the responses as it sometimes needs manual intervention.
Fixes: 303
AS you failed to respond to my post #7 on here, I assumed you had sorted it.
pvmb
@Phaeton wrote:
Does it actually do anything, I've been sending it a text for the last 4 weeks & not received a response or any improvement of speed.
No. Sending 'HELP' won't help.
That is the Plusnet automated line test phone number. It's correct use is, assuming a Plusnet landline, to send a text to 07800 008121 as follows:
PHONE <landline number to test>
For a BT supplied landline (this will redirect automatically to the Plusnet tester if a Plusnet line is detected) text to 61998:
Phaeton
Just tried this & I least I got a response, it was quite funny as I had no idea what the number is/was it's never been used, so had to logon to our account to find it.
