Does sending HELP to 07800 008121 Do anything?
Phaeton
Does it actually do anything, I've been sending it a text for the last 4 weeks & not received a response or any improvement of speed.
22 REPLIES 22
Fixes: 344
Re: Does sending HELP to 07800 008121 Do anything?
@Phaeton I'm not sure exactly how this works - I'm no longer a PN customer, so can't check, but using the two links here: https://www.plus.net/help/report-a-problem/phone/ or https://www.plus.net/help/report-a-problem/broadband/ actually ask you to carry out any tests prior to sending that text?
Fixes: 344
EDIT: If you don't get responses from that number, something is not quite right, as others have got them.
Maybe if you explained the issue on here, other Community members could offer advice.
Phaeton
Thank you, yes I've gone through the tests on the BB before sending the text, we've always got around 34Mb download fairly constantly for the past few years, but on the 11th March it dropped to 28Mb, then 6th May dropped to 20Mb, it has now recovered back to 28Mb, but to my untrained eye this looks like traffic shaping.
Fixes: 344
PN don't do traffic shaping - I suspect you have a fault. as you say you haven't had a response, maybe following the below would be useful.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Phaeton
Once again thank you, I have tried the BT test along with the Additional diagnostics multiple times, each time I do I am told the system is currently busy & to try again.
Unfortunately I am not able to do the quiet test as I do not have a phone, all my phones are VoIP the analogue line is purely there for Plusnet billing requirements.
Eventually I will admit defeat & call them if it doesn't improve
Fixes: 344
OK, ignoring the QLT, what about the rest of the information I requested - part answers to that help guide are rather pointless.
Gel
Champion
Fixes: 29
Azagoth
I'm currently trying to report a fault myself, and have just texted HELP to that number.  10 minutes later and no reply.  To be honest, I'm confused as how they are going to know which line to check for the broadband fault when I'm texting from my mobile and the phoneline my internet connection uses isn't provided by Plusnet.
Fixes: 344
@Azagoth It is not an 'instant response' system.
Phaeton
The issue is it's not even a 'response' system
@Azagoth I assume which is always dangerous, that they expect the mobile you are texting from to be on your account as a secondary contact number, which could be the downfall of the process.
Fixes: 344
@Phaeton It is a response system.
See mine and @MisterW 's later responses on @Azagoth 's topic.
Azagoth
Well, it's been an hour since I texted 'Help' now, not had a reply yet.
Fixes: 344
It is Sunday, and I suspect there  may be some manual input.
James30
Fixes: 32
@Azagoth - Hiya, the trouble with that number is that it interacts with our automated system and is used in conjunction with ringing 0800 432 0200 first to create a case. Not really sending texts to without ringing first but I've passed this on though incase it's not working or not doing something it's meant to. Is it your internet that you're having issues with?
James - Plusnet Sheffield
