Does contention at exchange alter sync rate
- Does contention at exchange alter sync rate
05-01-2009 10:51 AM
I know that contention at the excahnge will lower the overall through put of a connection but will contention itself reduce the the lines sync rate or is sync mainly down to line quality?
My understanding is that the sync rate should not chnage dramatically but speed of the info down the line will if too many local people are using the return path to the same isp.
Podman
Podman
Message 1 of 4
(1,027 Views)
3 REPLIES 3
Re: Does contention at exchange alter sync rate
05-01-2009 10:54 AM
Exchange contention will have no effect on your sync speed.
The sync speed is negotiated between your modem and the DSLAM. Contention affects the backhaul from the exchange to BT's network.
Message 2 of 4
(429 Views)
05-01-2009 11:40 AM
Just to echo what Paul has said - exchange contention has no bearing on sync speed whatsoever.
Message 3 of 4
(429 Views)
05-01-2009 12:08 PM
Cheers, I was just querying advice given in response to a raised ticket.
Podman
Podman
Message 4 of 4
(429 Views)
