Does anybody have a link to Retrain Reason codes?
- Re: Does anybody have a link to Retrain Reason cod...
29-02-2012 9:24 AM
I searched various forums but swamped with folks posted router stats, but does anyone have a link to any document/site that explains what Retrain Reason: 0, 1, 2, 8000 etc actually mean?
It's probably a dumb question and been asked before, so apologies if it has!
Pete
Pete
Message 1 of 5
(7,267 Views)
4 REPLIES 4
Re: Does anybody have a link to Retrain Reason codes?
29-02-2012 2:15 PM
That's not something I've heard of I'm afraid, do they only show on a particular brand of router? Where is it you're seeing the message?
Message 2 of 5
(3,079 Views)
29-02-2012 4:40 PM
Hi Matt,
If you telnet in to various routers that support it and do an xdslcmd info --show you get a whole string of data most of which makes sense, but on ADSL, ADSL2 and others I've seen various Retrain Reasons as per the one in red and have witnessed, a value of 0 , 2 and 8000 in the past.
I'm imagining it's something to do with a re-training condition but on my old ADSL2 line it was permanently on 8000. On my new service I've seen it at 0 and 2 which it currently is.
If I Google it then I see millions of examples of what I've just posted
# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = ?? Kbps, Downstream rate = ?? Kbps
Path: 0, Upstream rate = ?? Kbps, Downstream rate = ?? Kbps
Regards,
Pete
Status: Showtime
Retrain Reason: 2
Regards,
Pete
Message 3 of 5
(3,079 Views)
29-02-2012 4:45 PM
Hmm. A quick google has found this post on the thinkbroadband site: http://forums.thinkbroadband.com/fibre/t/4069505-more-fttc-line-stats.html
Not sure about reason 8000, but it looks like reason 2 is a loss of framing which is I believe something to do with the equipment at the exchange.
Message 4 of 5
(3,079 Views)
29-02-2012 5:08 PM
Cheers Matt,
I will sign up for incompetance at Googling
That sheds some light and especially as my line status is No Defect, I wonder if this is a historic code, i.e. the reason it last retrained was down to a Loss of Framing. Nice that the post relates to the modem I'm looking at!
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
It was 0 when first saw it and I re-booted it and I got a slightly higher sync rate and BT profile but it is on 2 now but totally stable.
Once again thankyou..
Pete
Trellis: U:ON /D:ON
Pete
Message 5 of 5
(3,079 Views)
