Does a new session cause interleaving?
- Does a new session cause interleaving?
30-04-2013 2:28 PM
I suspect that interleaving has been applied to my FTTC line. I'm just wondering whether rebooting the separate router(not the Openreach modem) multiple times might cause interleaving to be turned on?
Message 1 of 4
(749 Views)
3 REPLIES 3
Re: Does a new session cause interleaving?
01-05-2013 9:51 AM
Nobody knows?
Message 2 of 4
(415 Views)
01-05-2013 3:43 PM
Just ran a check on your line and it's currently showing interleaving as being off It's unlikely that rebooting the router would cause anything to happen DLM wise as the modem is what maintains the connection to the exchange.
Hope that helps.
Hope that helps.
Message 3 of 4
(415 Views)
01-05-2013 7:37 PM
Thanks for that. Strange, my f8lure graphs show a slightly higher rate of ping latency after I'd been messing about with my router - which is why I asked.
Message 4 of 4
(415 Views)
