Does Plusnet throttle Dropbox?
- Re: Does Plusnet throttle Dropbox?
13-01-2012 10:10 PM
The question is in the header. I've no complaints about my broadband speed, but my Dropbox service uploads very slowly with long periods at 0kbps. I have to restart about every 15 minutes.
Message 1 of 8
(2,056 Views)
7 REPLIES 7
13-01-2012 10:13 PM
I'm currently uploading at 0.2kbps. Not funny.
Message 2 of 8
(735 Views)
13-01-2012 11:16 PM
Plusnet don't restrict upload speeds at all apart from VPN on Plusnet Value which is restricted to 448kbps (significant only if upstream speeds are uncapped). Reference Upload Speeds Guide.
David
Message 3 of 8
(735 Views)
14-01-2012 10:26 AM
Many thanks for your help. I'll have to look elsewhere - or use another service.
Message 4 of 8
(735 Views)
14-01-2012 8:14 PM
Bit of a stab in the dark but you don't have 'Limit Automatically' enabled in settings do you?
Alex
Alex
Message 5 of 8
(735 Views)
16-01-2012 11:57 AM
Message 6 of 8
(735 Views)
16-01-2012 10:26 PM
Quote from: spraxyt Plusnet Value which is restricted to 448kbps...
What should be the upstream speed for Plusnet Extra?
Message 7 of 8
(735 Views)
17-01-2012 1:01 AM
Sync speeds don't depend on product. For an ADSLmax service upstream sync speed should be 448kbps or 832kbps with Max Premium (additional cost option). For 21CN/WBC it is nominally 448kbps unless uncapped in which case it would depend on line capability. Max achievable is just over 1Mbps.
David
David
David
Message 8 of 8
(735 Views)
