Does PlusNet use Traffic Management
- Does PlusNet use Traffic Management
01-03-2021 11:39 PM
Searching this Forum, I came across this announcement:
From 29th June 2017, Traffic Prioritisation is no longer applied to our current Unlimited and Unlimited Fibre products.
Is this still true for ADSL (non-Fibre) Unlimited product?
Re: Does PlusNet use Traffic Management
02-03-2021 7:02 AM
@Wheel_nut The statement applies to all Unlimited products. Unlimited = ADSL and Unlimited Fibre = FTTC.
02-03-2021 10:16 AM
@RealAleMadrid Thank you for your clarification. I have been experiencing quite a bit of latency but that may be due to DNS issues.
Do most of you use the PlusNet DNS or is there a generally accepted better one?
02-03-2021 2:21 PM
There have been reports of the Plusnet Hub One being reluctant to pass DNS requests on.
However, these were typically stopping all DNS forwarding until rebooted.
Are you using a Plusnet supplied router?
If so the DNS servers are fixed to Plusnet ones. The only way to bypass is to set the DNS manually on each device.
I personally do not use a Plusnet supplied router and I have configured the router to use OpenDNS.
A friend of mine is happy using the Cloudfare DNS.
Regards
Richard
02-03-2021 8:47 PM
Hi Richard,
No I am using a BT Hub 6. I never even bothered to open the PlusNet supplied Router.
The BT Hub 6 has been rock solid for me for over two years and the WiFi strength is excellent for my needs.
Robin
