Does PN charge for replacement routers ?
- Re: Does PN charge for replacement routers ?
01-08-2013 1:03 PM
Hi all
When I was with 02, they used to send you another router completely free of charge. Is this the case with PN ?
Thanks.
Thanks.
Message 1 of 6
(2,567 Views)
5 REPLIES 5
01-08-2013 2:17 PM
I would imagine that if the supplied router developed a fault, or was suspect of being faulty within the 1st 12mths then i would say it would bew replaced free of charge under warranty, if after 2 or more years i would think that it would then be down to plusnet's discretion / company policy , as i doubt they would be in any way obliged to provide a new router FOC
Both o2 & BE support had a habit of nearly always replacing the supplied router each time a customer reported problems, either those routers where really very poor quality, or they favoured replacing the router as opposed to BT openreach involvement ?
With BE the router was only loaned not given, so when customers left BE the router had to be returned or they charged a £35 fee for it, and it was locked to their network, as are i think the o2 routers ,so they are of no use with other isp's So that is the fundamental difference you own the plusnet router , where as o2/be only loaned them out
Message 2 of 6
(614 Views)
01-08-2013 3:14 PM
Quote from: deathtrap I would imagine that if the supplied router developed a fault, or was suspect of being faulty within the 1st 12mths then i would say it would bew replaced free of charge under warranty, if after 2 or more years i would think that it would then be down to plusnet's discretion / company policy , as i doubt they would be in any way obliged to provide a new router FOC
Thanks DT.
And do you know how much the charge would be (if any) ?
Message 3 of 6
(614 Views)
01-08-2013 3:16 PM
We wouldn't charge you if the router was faulty in the first 12 months.
Message 4 of 6
(614 Views)
01-08-2013 3:36 PM
Quote from: James We wouldn't charge you if the router was faulty in the first 12 months.
Thanks James.
And what about after the12 months ?
Message 5 of 6
(614 Views)
01-08-2013 3:45 PM
P&P plus 12 month tie in
Or buy a better one
Or buy a better one
Message 6 of 6
(614 Views)
