Dodgy Router?
- Dodgy Router?
Dodgy Router?
02-02-2012 12:06 PM
Re: Dodgy Router?
02-02-2012 12:16 PM
Re: Dodgy Router?
02-02-2012 12:33 PM
Re: Dodgy Router?
02-02-2012 12:47 PM
hey, don't think like that, the staff and mods here are happy to help people with what ever level of knowledge they might have.
Quote Sorry to sound thick Adam
You can do this by logging into the settings page for your router (refer to it's manual for that: http://www.belkin.com/uk/support/article/?lid=enu&pid=f5d7634uk4a&aid=14448&scid..)
set up pages on a router are usually broken down into sections so look for wireless settings and you should have an option in there.
Re: Dodgy Router?
02-02-2012 12:50 PM
Re: Dodgy Router?
02-02-2012 1:06 PM
Re: Dodgy Router?
02-02-2012 7:49 PM
Re: Dodgy Router?
03-02-2012 3:15 PM
It looks like your router is losing connection with the exchange from checking our connection logs:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13282820366984.png" />
I'd recommend running through the troubleshooter at http://faults.plus.net as that'll take you through testing with the router in the master socket etc. If the line still drops after those tests then you've confirmed it's a fault with the line itself, and we'll get it escalated and investigated for you.
Re: Dodgy Router?
04-02-2012 5:12 PM
Re: Dodgy Router?
06-02-2012 11:52 AM
