Do you get dial-up with a broadband account?
- Do you get dial-up with a broadband account?
05-10-2008 10:36 PM
Since the broadband only works on the one line that BT hook up to the exchange I can't use it to access the net if I go elsewhere (family/friend's house, etc.). I know if there's a suspected fault with the BB you get a dial-up backup number, but is one available for everyday use that would associate with my account? If so, is it free, charged at lo-call rates, full rate, etc?
There are (used to be, anyway) one or two dial-up numbers from ISPs that don't require any signing up, and I've got an old account with another ISP that I keep alive, but these wouldn't allow me to directly access things like my email as if I'm hooked into PlusNet.
Re: Do you get dial-up with a broadband account?
05-10-2008 10:40 PM
All Broadband accounts have 0845 dialup access included, on 08451400101 for Plusnet visp customers.
When your line gets a fault you get specific 0808 access which means you don't have to pay for the calls.
06-10-2008 9:19 AM
06-10-2008 9:20 AM
B.
06-10-2008 10:19 AM
I think if you connect via dial-up PN's systems will try to assign the same IP address as is allocated to the broadband connection (particularly if you have a static IP - I may be wrong though!). This is what will cause issues if both are connected.
If I need to use a dial-up connection for short periods I tend to use UKU - no account needed and is fine for the short spells that I've needed a dial-up when away from home (and doesn't cause my wife any probs using broadband).
The other option would be a free dial-up account from PN.
06-10-2008 2:24 PM
I'd assumed it would just be a standard dynamic-IP dial-up.
06-10-2008 3:15 PM
You'd be able to use any other dialup supplier at the same time though. You'd be able to get a free dialup connection from pretty much anywhere.
06-10-2008 5:50 PM
It would still be a PN connection though, so you'd still be able to do things such as collect mail for your home account, or access your webspace.
07-10-2008 12:55 AM
07-10-2008 1:22 AM
this will be your member centre login details.
07-10-2008 1:28 AM
07-10-2008 11:50 AM
That way, you are connected to our network, but not with your account details.
Ian
07-10-2008 1:09 PM
It seems there are many options to get something to more or less work.
Re. the SMTP-AUTH feature - Is there a reason why this doesn't accept encrypted password details? It seems a little unsafe to be transmitting my top-level account user/pass in the clear. Or is it actually the mailbox user/pass I'm supposed to use?
07-10-2008 8:24 PM
it's unencrypted password auth, should be your member centre login (which is the same as your default mailbox one).
I don' think that someone would be intercepting the connection unless you have a trojan/backdoor on your pc
Should be ok to use it from dial up to send email as long as you are using your broadband account details.
