Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
- Do want to use a BT Homehub 3 or 2 on Plusnet ADSL...
Re: Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
02-01-2014 9:36 PM
http://www.ebay.co.uk/itm/301053628441
02-01-2014 9:39 PM
02-01-2014 9:50 PM
My engineer was fussy about home hubs on plus net he said u had to use pn router. But I swapped anyway after he'd gone.
02-01-2014 10:26 PM
02-01-2014 10:52 PM
Connect your computer to the router and open up a browser and put in address bar http://192.168.1.254 the routers configuration page.
The credentials are I think Admin and password is under the router beginning with CP
Go to DSL then disconnect the connection. Disconnect everything.
Plug the RJ11 cable that used to go into the modem into the hub 5 grey DSL port not the red port.
Then follow steps to post 1.
A simpler option is just disconnect the router and modem and plug hub 5 and connect the rj11 cable. Disconnecting via browser is not necessary.
PM me if you get stuck
02-01-2014 11:28 PM
OK. So when the engineer turns up I don't think I will mention the HH5, and just let him install the modem and everything else, and then take it from there.
Thanks for the walk through NorthEasterner, and I might just have to take you up on that PM
03-01-2014 8:15 AM
There were updates for example on Christmas Day or therabouts, and undoubtedly more to come.
https://community.bt.com/t5/Other-BB-Queries/Home-hub-5-firmware-Update/td-p/1119530
I don't believe there is any option to manually update the firmware.
Details of the current firmware versions are here:
http://bt.custhelp.com/app/answers/detail/a_id/13073/~/how-can-i-check-the-firmware-version-on-my-bt...
03-01-2014 9:46 AM
No I don't think it will update on non BT broadband services. As I believe it's delivered via BT broadband
03-01-2014 10:19 AM
04-01-2014 1:48 PM
Pretty impressive - getting 15MB /sec to my microserver, though I think I've seen the 2.4GHz wifi stall on my android phone a couple of times.
Jaggies - so you received HH4 updates via the router connected to Plusnet's network? I wonder what the mechanism actually is as I was under the impression the updates don't go out all in one go.
04-01-2014 6:19 PM
04-01-2014 7:03 PM
Does the router first connect to somewhere else before making the PPPOE connection to Plusnet?
I see the entry is actually truncated in the log and ends .motive.com
04-01-2014 7:09 PM
04-01-2014 7:15 PM
That is good. It must be acquiring updates via Internet and not on the BT line.
04-01-2014 7:17 PM
