Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
- Do want to use a BT Homehub 3 or 2 on Plusnet ADSL...
Re: Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
04-01-2014 7:18 PM
04-01-2014 8:09 PM
04-01-2014 9:21 PM
04-01-2014 10:37 PM
http://vwlowen.co.uk/RouterStatsHub/routerstatshub.htm
05-01-2014 10:42 PM
It downloaded the update around 10am but looks like it was waiting for a quiet time to reboot. I rebooted it from the web UI and it did the update.
Can't see any improvement from the update, seems no-one knows what the update is for.
I am lukewarm on this router. I think the 2.4GHz is actually nothing special at all (in fact, I think slower than the TG582N in the same location), but the 5GHz is extremely fast for bulk transfers (I've seen as high as 30MB/sec - no joke - to my little microserver from the macbook). The macbook has failed to connect to the 2.4GHz a few times (particularly if you have been connected to the 5GHz previously it seems). No WAN ping response option is annoying but I've dealt with that.
That said, it is nice have an all-in-one box consuming less power and mains sockets, and it was dirt cheap for a simultaneous dual band router with VDSL, plus the ability to monitor a limited set of linestats without hacking the box is cool.
06-01-2014 11:31 AM
Early days so will play some more.
06-01-2014 7:17 PM
BTHub5-J7H4_5GHz
and the 2.4GHz just BTHub5-J7H4
The SSID is fictional all i've done is added an underscore and 5GHz to represent the 5GHz band.
06-01-2014 7:21 PM
06-01-2014 8:08 PM
06-01-2014 8:35 PM
"IPv6 Configuration
IPv6 Configuration is not currently enabled as your BT Home Hub and/or BT Broadband Network are not enabled for IPv6"
and again for IPV6 pinholes:
"IPv6 Pinholes
IPv6 Pinholes are not currently enabled as your BT Home Hub and/or BT Broadband Network are not enabled for IPv6"
06-01-2014 9:23 PM
06-01-2014 11:58 PM
Quote from: jimbof IPv6 Configuration is not currently enabled as your BT Home Hub and/or BT Broadband Network are not enabled for IPv6"
Unless you are on the IPv6 trial you don't know if the router is IPv6 ready or not. I'd be astounded if it wasn't. If someone would like to lend me one I'll tell you if it works or not on an IPv6 enabled connection!
07-01-2014 6:32 AM
Quote from: jimbof Yeah I did that - any idea what the logic is as to why it is a good idea though? Just so you know which you are connected to?
It supposed to separate the bands apart as mine used to cause interference and my WiFi would keep disconnecting and reconnecting to the different bands.
5GHz covers all of my house so I use the laptop on the 5GHz band and it doesn't know the 2.4GHz band.
Smartphones connect to 5GHz band and get's wifi all over house. There is only a few devices on the 2.4GHz band, iPod touch, Sky boxes (via a connector from Sky) and 1 iPhone.
07-01-2014 7:00 AM
I think I'm probably going to just use this as a cheap, fast dual-band AC access point and go back to my homebrew router; one thing which is annoying me is the random allocation to a plusnet gateway which is measurably slower latency-wise than the others (I had a script on my openWRT box to drop and reconnect if it got one of those connections). I've also seen some wired performance weirdness - yesterday my wired speedtests to thinkbroadband were capped at 20megabits/sec while WIFI was fine, as were wired connections to other speedtest sites and my microserver (it was like some QOS engine in the router had gone wrong). Reboot fixed it.
07-01-2014 10:39 AM
