Do Some Gateways Block Certain Sites?
- Do Some Gateways Block Certain Sites?
Re: Do Some Gateways Block Certain Sites?
29-04-2012 1:16 PM
Not sure myself if this is anything to do with DNS but it's always interesting to read these technical asides.
29-04-2012 1:39 PM
I find that if this page - https://signin.ebay.co.uk, doesn't load then MTU on router is too high.
My previous Linksys routers used to be happy with MTU=1500, but my current Netgear DG834GT gives best results with MTU=1430, with no loss of download speed.
29-04-2012 1:47 PM
Did you try gateway hopping?
29-04-2012 2:19 PM
I've seen it happen a couple of times before and changing gateway always fixes it. Unfortunately I didn't check which gateway it was at the time but in the previous post I did get one.
29-04-2012 2:21 PM
If that question is for me, then I gateway hop every time I notice that my connection is running slowly, but have set my MTU so that my connection ALWAYS works.
I can't say that I have ever noticed a correlation between sites not loading and which gateway I'm on - but I have not been looking for that, only how to get the best speedtests with all pages I visit being accessible AND zero packet resends or fragmentation.
As you can see from my signature below, I get speedtest results that match the maximum theoretical IP profile possible (7150Kbps) on my 8Mb 20CN connection, using the MTU=1430.
I'm happy with my connection and see no advantage in trying to achieve a higher MTU.
I can load problematic pages with a higher MTU (like 1458), but packet losses start to appear when doing speedtests or large file transfers.
29-04-2012 2:56 PM
Quote from: RPMozley I don't think it's due to MTU as after gateway hopping the site loads perfectly fine.
That makes me think a MTU issue is a possibility - on the gateway itself or somewhere in the BT network.
Here's a previous issue:
http://community.plus.net/forum/index.php?topic=31484.0 and http://usergroup.plus.net/forum/index.php/topic,4411.0.html
There have been other similar issues in the past when new gateways are introduced.
29-04-2012 3:08 PM
Here are the previous instances of loops in the routing on ptn gateways:
http://community.plus.net/forum/index.php/topic,96555.msg814238.html#msg814238
http://community.plus.net/forum/index.php/topic,103624.0.html
The exact error message if the problem is a loop in the routing should be something like: destination unreachable - TTL exceeded.
29-04-2012 6:39 PM
30-04-2012 7:02 AM
traceroute -T -p 80 www.filefactory.com
traceroute to www.filefactory.com (85.17.172.100), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 4.351 ms 4.687 ms 5.582 ms
2 lo0-central5.ptn-ag04.plus.net (195.166.130.83) 22.481 ms 25.222 ms 26.373 ms
3 84.93.253.83 (84.93.253.83) 28.185 ms 31.624 ms 32.047 ms
4 po4.ptn-gw01.plus.net (212.159.1.138) 34.191 ms 35.452 ms 37.842 ms
5 tun0.ptn-gw01.plus.net (212.159.2.101) 39.100 ms 41.584 ms 42.735 ms
6 vl69.ptw-gw02.plus.net (212.159.3.253) 44.520 ms 41.340 ms 43.225 ms
7 po4.ptn-gw01.plus.net (212.159.1.138) 45.157 ms 29.244 ms 29.375 ms
8 tun0.ptn-gw01.plus.net (212.159.2.101) 29.147 ms 28.459 ms 28.821 ms
9 vl69.ptw-gw02.plus.net (212.159.3.253) 29.616 ms 29.895 ms 29.594 ms
10 po4.ptn-gw01.plus.net (212.159.1.138) 29.558 ms 19.213 ms 21.018 ms
11 tun0.ptn-gw01.plus.net (212.159.2.101) 23.435 ms 19.262 ms 22.138 ms
12 vl69.ptw-gw02.plus.net (212.159.3.253) 23.216 ms 25.023 ms 26.548 ms
13 po4.ptn-gw01.plus.net (212.159.1.138) 28.879 ms 31.378 ms 31.897 ms
14 tun0.ptn-gw01.plus.net (212.159.2.101) 34.995 ms 35.330 ms 37.909 ms
15 vl69.ptw-gw02.plus.net (212.159.3.253) 40.179 ms 41.365 ms 44.378 ms
16 po4.ptn-gw01.plus.net (212.159.1.138) 44.899 ms 47.262 ms 30.423 ms
17 tun0.ptn-gw01.plus.net (212.159.2.101) 30.052 ms 30.401 ms 30.458 ms
18 vl69.ptw-gw02.plus.net (212.159.3.253) 28.778 ms 29.327 ms 29.936 ms
19 po4.ptn-gw01.plus.net (212.159.1.138) 30.197 ms 29.872 ms 30.950 ms
20 tun0.ptn-gw01.plus.net (212.159.2.101) 30.615 ms 30.789 ms 30.154 ms
21 vl69.ptw-gw02.plus.net (212.159.3.253) 31.518 ms 31.184 ms 30.430 ms
22 po4.ptn-gw01.plus.net (212.159.1.138) 31.414 ms 30.403 ms 30.267 ms
23 tun0.ptn-gw01.plus.net (212.159.2.101) 30.082 ms 31.281 ms 30.224 ms
24 vl69.ptw-gw02.plus.net (212.159.3.253) 30.237 ms 29.632 ms 29.739 ms
25 po4.ptn-gw01.plus.net (212.159.1.138) 30.070 ms 29.487 ms 30.609 ms
26 tun0.ptn-gw01.plus.net (212.159.2.101) 30.477 ms 27.872 ms 28.502 ms
27 vl69.ptw-gw02.plus.net (212.159.3.253) 29.217 ms 28.200 ms 28.881 ms
28 po4.ptn-gw01.plus.net (212.159.1.138) 30.075 ms 29.675 ms 30.415 ms
29 tun0.ptn-gw01.plus.net (212.159.2.101) 30.865 ms 29.969 ms 31.731 ms
30 vl69.ptw-gw02.plus.net (212.159.3.253) 29.691 ms 29.071 ms 29.593 ms
30-04-2012 9:43 AM
After the network came back up after the last crash (Thursday 19th) I did some Gateway hopping. I landed on 195.166.130.100 I'm afraid I didn't make any further notes or check the gateway name (or do any other tests) - I just couldn't browse anywhere, zilch. IP address at the time was 31.185.224.136 (my MTU is 1500 in case MTU becomes relevant) (20CN as well).
I just hopped to another gateway and carried on with what I was doing before the crash.
30-04-2012 10:07 AM
Tracing route to filefactory.com [85.17.172.100]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms RTA1335.home [192.168.1.1]
2 35 ms 36 ms 37 ms lo0-central3.pcl-ag02.plus.net [195.166.128.237]
3 81 ms 34 ms 34 ms gi1-23-232.pcl-gw02.plus.net [84.92.6.50]
4 38 ms 33 ms 34 ms tun0.pcl-gw01.plus.net [212.159.2.105]
5 36 ms 34 ms 34 ms flowers2.servers.plus.net.uk [212.159.2.98]
6 36 ms 3807 ms 35 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
7 34 ms 35 ms 34 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 35 ms 34 ms 34 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
9 35 ms 35 ms 35 ms vlan101.ebr2.London1.Level3.net [4.69.143.86]
10 41 ms 44 ms 44 ms ae-45-45.ebr2.Amsterdam1.Level3.net [4.69.143.69]
11 47 ms 49 ms 49 ms ae-56-221.csw2.Amsterdam1.Level3.net [4.69.153.202]
12 83 ms 42 ms 44 ms 4.69.162.150
13 42 ms 47 ms 47 ms FIBERRING-B.edge5.Amsterdam1.Level3.net [212.72.41.142]
14 41 ms 44 ms 44 ms po100.hv1.evo.leaseweb.net [85.17.100.222]
15 52 ms 51 ms 50 ms www.filefactory.com [85.17.172.100]
Trace complete.
1 <1 ms <1 ms <1 ms RTA1335.home [192.168.1.1]
2 95 ms 129 ms 114 ms lo0-central3.pcl-ag02.plus.net [195.166.128.237]
3 241 ms 232 ms 325 ms gi1-23-232.pcl-gw02.plus.net [84.92.6.50]
4 61 ms 329 ms 218 ms tun0.pcl-gw01.plus.net [212.159.2.105]
5 34 ms 35 ms 34 ms flowers2.servers.plus.net.uk [212.159.2.98]
6 36 ms 34 ms 35 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
7 34 ms 34 ms 34 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 37 ms 34 ms 34 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
9 34 ms 36 ms 37 ms vlan101.ebr2.London1.Level3.net [4.69.143.86]
10 44 ms 44 ms 45 ms ae-45-45.ebr2.Amsterdam1.Level3.net [4.69.143.69]
11 53 ms 49 ms 49 ms ae-56-221.csw2.Amsterdam1.Level3.net [4.69.153.202]
12 41 ms 43 ms 44 ms 4.69.162.150
13 47 ms 47 ms 47 ms FIBERRING-B.edge5.Amsterdam1.Level3.net [212.72.41.142]
14 44 ms 44 ms 44 ms po100.hv1.evo.leaseweb.net [85.17.100.222]
15 54 ms 51 ms 54 ms www.filefactory.com [85.17.172.100]
Trace complete.
30-04-2012 10:23 AM
$ mtr filefactory.com
HOST: my_desktop Loss% Snt Last Avg Best Wrst StDev
1. my_gateway 75.0% 100 3.7 4.2 3.0 7.5 1.3
2. lo0-central1.pcl-ag03.plus.n 18.0% 100 29.1 28.4 22.9 151.4 14.9
3. gi1-9-312.pcl-gw02.plus.net 6.0% 100 32.8 44.5 31.4 245.8 38.9
4. tun0.pcl-gw01.plus.net 32.0% 100 33.5 38.1 31.6 218.1 24.9
5. flowers2.servers.plus.net.uk 52.0% 100 35.0 33.1 31.2 38.4 1.5
6. xe-11-1-0.edge3.London2.Leve 13.0% 100 33.0 33.8 31.5 72.1 4.6
7. ae-0-11.edge4.London2.Level3 25.0% 100 32.0 36.2 30.8 85.6 10.1
8. ae-3-3.ebr1.London1.Level3.n 60.0% 100 33.9 33.5 31.7 38.6 1.4
9. vlan103.ebr2.London1.Level3. 14.0% 100 32.7 33.4 31.7 37.6 1.1
10. ae-48-48.ebr2.Amsterdam1.Lev 13.0% 100 40.1 40.8 39.2 46.0 1.2
11. ae-57-222.csw2.Amsterdam1.Le 57.0% 100 51.1 43.0 39.3 51.6 4.0
12. 4.69.162.158 29.0% 100 39.5 41.0 39.2 62.6 2.9
13. LEASEWEB.edge5.Amsterdam1.Le 9.0% 100 45.8 44.9 40.3 50.3 2.5
14. po100.hv1.evo.leaseweb.net 58.0% 100 45.2 46.0 40.1 222.3 27.9
15. 85.17.172.100 31.0% 100 47.0 46.7 34.1 54.9 5.0
$ mtr plus.net
1. my_gateway 0.0% 100 3.1 4.0 2.9 8.9 1.3
2. lo0-central1.pcl-ag03.plus.n 0.0% 100 34.4 30.2 22.9 81.9 11.0
3. gi1-9-312.pcl-gw02.plus.net 0.0% 100 33.2 53.5 25.8 303.0 52.0
4. po4.pcl-gw01.plus.net 0.0% 100 40.3 50.5 39.0 268.6 34.8
5. gi5-8.ptp-cr01.plus.net 0.0% 100 40.6 40.9 38.9 50.1 1.7
6. vlan2658.ptp-elb02.plus.net 0.0% 100 40.7 42.8 33.4 78.4 4.5
7. portal.plus.net 0.0% 100 40.1 41.8 39.3 54.2 1.8
30-04-2012 2:53 PM
[tt]traceroute --mtu www.filefactory.com
traceroute to www.filefactory.com (85.17.172.100), 30 hops max, 65000 byte packets
1 192.168.0.1 (192.168.0.1) 2.452 ms F=1500 2.328 ms 3.564 ms
2 lo0-central5.ptn-ag04.plus.net (195.166.130.83) 52.777 ms 51.996 ms 49.500 ms
3 84.93.253.83 (84.93.253.83) 48.470 ms 48.974 ms 48.639 ms
4 po4.ptn-gw01.plus.net (212.159.1.138) 48.402 ms 48.842 ms 48.219 ms
5 tun0.ptn-gw01.plus.net (212.159.2.101) 47.488 ms F=1476 46.969 ms 47.366 ms
6 195.99.126.144 (195.99.126.144) 48.256 ms 47.630 ms 47.347 ms
7 ten4-0.lon.leaseweb.net (195.66.225.56) 58.583 ms 55.355 ms 54.402 ms
8 po100.hv1.evo.leaseweb.net (85.17.100.222) 70.224 ms 55.675 ms 55.753 ms
9 85.17.172.100 (85.17.172.100) 62.810 ms 58.319 ms 61.287 ms[/tt]
[tt]ping -s 1448 www.filefactory.com
PING www-origin.filefactory.com (85.17.172.100) 1448(1476) bytes of data.
1456 bytes from 85.17.172.100: icmp_req=1 ttl=57 time=60.6 ms
1456 bytes from 85.17.172.100: icmp_req=2 ttl=57 time=62.9 ms
1456 bytes from 85.17.172.100: icmp_req=3 ttl=57 time=61.5 ms
1456 bytes from 85.17.172.100: icmp_req=4 ttl=57 time=67.2 ms
--- www-origin.filefactory.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 60.674/63.103/67.299/2.570 ms
ping -s 1449 www.filefactory.com
PING www-origin.filefactory.com (85.17.172.100) 1449(1477) bytes of data.
From po4.ptn-gw01.plus.net (212.159.1.138) icmp_seq=1 Frag needed and DF set (mtu = 1476)
7 packets transmitted, 0 received, +1 errors, 100% packet loss, time 6001ms[/tt]
Also, 195.99.126.144 is going via BT rather than Level 3.
01-05-2012 7:00 PM
Sites timing out, including all Hurricane Electric domains (www.he.net is the main one) and http://ipv6-test.com/
Forgot to check FileFactory at the time (not with it at mo with this nasty cold).
01-05-2012 7:26 PM
also
Tracing route to he.net [216.218.186.2]
1 1 ms <1 ms 1 ms RTA1335.home [192.168.1.1]
2 36 ms 47 ms 36 ms lo0-central3.pcl-ag02.plus.net [195.166.128.237]
3 151 ms 83 ms 219 ms gi1-23-232.pcl-gw02.plus.net [84.92.6.50]
4 35 ms 35 ms 33 ms ae3.pcl-cr02.plus.net [195.166.129.42]
5 37 ms 34 ms 51 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 33 ms 34 ms 34 ms po2.ptw-gw02.plus.net [195.166.129.39]
7 40 ms 37 ms 36 ms 10gigabitethernet1-1.core1.lon1.he.net [195.66.224.21]
8 110 ms 104 ms 104 ms 10gigabitethernet7-4.core1.nyc4.he.net [72.52.92.241]
9 172 ms 174 ms 174 ms 10gigabitethernet10-2.core1.sjc2.he.net [184.105.213.197]
10 219 ms 172 ms 176 ms 10gigabitethernet1-1.core1.fmt1.he.net [72.52.92.109]
11 172 ms 174 ms 173 ms www.he.net [216.218.186.2]
Trace complete.
Another try
1 <1 ms 1 ms <1 ms RTA1335.home [192.168.1.1]
2 38 ms 41 ms 37 ms lo0-central3.pcl-ag02.plus.net [195.166.128.237]
3 34 ms 35 ms 36 ms gi1-23-232.pcl-gw02.plus.net [84.92.6.50]
4 39 ms 514 ms 36 ms ae3.pcl-cr02.plus.net [195.166.129.42]
5 45 ms 34 ms 46 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 36 ms 34 ms 34 ms po2.ptw-gw02.plus.net [195.166.129.39]
7 33 ms 35 ms 33 ms 10gigabitethernet1-1.core1.lon1.he.net [195.66.224.21]
8 105 ms 104 ms 113 ms 10gigabitethernet7-4.core1.nyc4.he.net [72.52.92.241]
10 178 ms 176 ms 176 ms 10gigabitethernet1-1.core1.fmt1.he.net [72.52.92.109]
11 172 ms 175 ms 174 ms www.he.net [216.218.186.2]
Trace complete.
