Do PlusNet Block Ports Used for SIP
- Do PlusNet Block Ports Used for SIP
10-10-2010 1:33 PM
I'm wondering whether PlusNet block the typical SIP and STUN ports (5060 and 10000). I have a VoIP account with sipgate and was with PlusNet a couple of years ago and all worked fine. Now I find with identical configuration at my new home that my router can not connect to sipgate.
I have no particular desire to subscribe to PlusNet's own VoIP service.
Message 1 of 5
(2,652 Views)
4 REPLIES 4
Re: Do PlusNet Block Ports Used for SIP
10-10-2010 1:37 PM
Check your PlusNet Firewall settings https://portal.plus.net/my.html?action=firewall , it needs to be Low ( or Off ).
Message 2 of 5
(864 Views)
10-10-2010 1:48 PM
Hello, I have Sipgate, Gradwell and AQL VoIP services running fine over my Plus.net ADSL connection.
Regards,
Neal.
Regards,
Neal.
Message 3 of 5
(864 Views)
10-10-2010 2:04 PM
Thanks for the info. PlusNet firewall is off. Looks like I need to check my router setup again.
Message 4 of 5
(864 Views)
11-10-2010 2:31 AM
Quote from: jjlukfr I'm wondering whether PlusNet block the typical SIP and STUN ports (5060 and 10000).
no they dont
If you have a speedtouch router you need to telnet the router and unbind port 5060, it solved my problem with sipgate
I dont understand why you dont want to have plusnet voip service? depending what contract you have you could get free calls, i get 240 minutes free.
You can have more than one account depending what equipment you have
kind regards
puddy
Message 5 of 5
(864 Views)
