Do I win a prize??
dawson
Do I win a prize??
got this earlier this evening - I'm having some right old fun and games Wink
and then tried this too...
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=1882ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1931ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1609ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1720ms TTL=120
Shocked Shocked Shocked
i think its improved in the last few minutes though....
is there an outage somewhere is my connection really s**t?
dawson
Re: Do I win a prize??
and here's another more recent speedtest...
jojopillo
HI dawson,
your profile is showing as 4500 and the exchange shows there's been no incidents and the VP is showing as green. Have you had a look at our troubleshooting guide for slow speed where you are advised to perform 3 speed tests at speedtester.bt.com. If so, I would suggest you confirm via your open ticket and answer the most recent sent to you. On'ce you have done this I will raise it as a fault for you.
Jojo Smiley
