Do I win a prize??
- Re: Do I win a prize??
Do I win a prize??
28-11-2010 9:52 PM
got this earlier this evening - I'm having some right old fun and games
and then tried this too...
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=1882ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1931ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1609ms TTL=120
Reply from 212.58.224.138: bytes=32 time=1720ms TTL=120
i think its improved in the last few minutes though....
is there an outage somewhere is my connection really s**t?
Message 1 of 3
(660 Views)
2 REPLIES 2
28-11-2010 9:55 PM
Message 2 of 3
(340 Views)
29-11-2010 1:05 PM
HI dawson,
your profile is showing as 4500 and the exchange shows there's been no incidents and the VP is showing as green. Have you had a look at our troubleshooting guide for slow speed where you are advised to perform 3 speed tests at speedtester.bt.com. If so, I would suggest you confirm via your open ticket and answer the most recent sent to you. On'ce you have done this I will raise it as a fault for you.
Jojo
Jojo
Message 3 of 3
(340 Views)
