Do I need to inform Plusnet?
tarren
I have signed up with Vodaphone, do I have to inform Plusnet?
All Star
Fixes: 6
Re: Do I need to inform Plusnet?
In a word, no. Transfers are 'gaining provider lead' - in other words, Vodaphone should handle it for you.
HTH
Fixes: 4
If you are migrating broadband and/or telephone landline, then NO.
If you are porting a mobile phone number then YES - but only to get the PAC code.
All Star
Fixes: 6
@Nibiru Good point, but as the OP posted in the Broadband forum, I assumed that was what they were referring to.
tarren
Thank you for your replies gentlemen,It is only BB and phone I am migrating.
Fixes: 416
Hi there. I'm sorry to hear you're leaving us.
May I ask if there's a particular reason why? And anything we can do to convince you to stay? -Anoush
tarren
Hello
