Do I need fibre? (not a bowel related question)
- Do I need fibre? (not a bowel related question)
- « Previous
- Next »
Re: Do I need fibre? (not a bowel related question)
18-01-2014 3:09 PM
It could be that someone near to you has started using the same wireless channel as you. Have you tied using different channels?
18-01-2014 5:15 PM
Before I go ahead and order that adapter kit, how do I go about checking and/or changing my wireless channel?
18-01-2014 5:21 PM
18-01-2014 5:28 PM
Now we can watch that final episode of Sherlock and the little one can get back into the Night Garden!
Peace returns to the house.
20-01-2014 9:06 PM
iplayer worked fine yesterday but this evening it keeps slowing down/buffering.
So do I change the channels again...?
30-01-2014 9:08 PM
If it's not sorted out within two weeks then I will switch to another provider.
30-01-2014 9:32 PM
The homeplugs (http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4) I suggested earlier would probably be your best solution.
Your initial question was about fibre. As it's the wireless that is causing the issue and not your broadband connection speed fibre isn't going to help. If you did upgrade to fibre at some time in the future the homeplugs would still be useful.
31-01-2014 12:51 AM
Quote from: DrJon It's wi-fi.
I don't know much about fancy TV's either, this is the first TV we've had for several years!
How far is your router from the TV???
I have exact same tv and mine works fine. My router is right next to my tv though
31-01-2014 9:08 PM
People here are making lots of reasonable suggestions and you have proven that some (changing channel) work. You can also try turning off your portable/wireless home phone for an evening if you have one as these can cause issues too with wifi range.
So, what you should do is...
1. Move the wifi router a bit nearer your TV even if it is just for an evening to prove that a better connection solves the problem. Put it on a table in the middle of the room or something just to prove the point.
2. By the homeplug things - it will 99.5% solve it and if 1. above solves it then it should 100% solve it.
3. See if there is a firmware update for your TV - as you said it was last year's model I think, there could be, but this is a bit of a faf
31-01-2014 11:21 PM
02-02-2014 9:40 AM
02-02-2014 3:26 PM
If you've been with them a while and also since you've just upgraded packages they might be able to sort something.
I'm thinking the newer router will have a different wi-fi chip and also 802.11n support so it might behave a bit better with the TV
02-02-2014 3:40 PM
- « Previous
- Next »
