Do I have the slowest broadband?
- Do I have the slowest broadband?
27-08-2011 8:30 AM
Message 1 of 5
(958 Views)
4 REPLIES 4
Re: Do I have the slowest broadband?
27-08-2011 9:35 AM
At a guess you may be on a 1Mb fixed speed product
Can you post your router stats http://community.plus.net/forum/index.php/topic,96155.0.html
Message 2 of 5
(470 Views)
27-08-2011 10:59 AM
Mine are close,I live about halfway between Oxford and Reading.
Message 3 of 5
(470 Views)
14-09-2011 8:16 PM
Quote from: Oldjim At a guess you may be on a 1Mb fixed speed product
Sorry for the delay Oldjim, here are the stats;
Uptime: 0 days, 0:18:40
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 868 / 1,664
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,472
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 5.84
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 28.0 / 60.0
SN Margin (Up/Down) [dB]: 17.0 / 9.0
Vendor ID (Local/Remote): TMMB / P
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 10,952
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
The router has only just been hard reset as again we were having problems with it, so not sure if you have enough info. What can you decipher from these numbers?
Message 4 of 5
(470 Views)
14-09-2011 8:28 PM
Message 5 of 5
(470 Views)
