Do I have an issue?
- Do I have an issue?
Do I have an issue?
30-11-2014 6:26 AM
Nov 30 06:18:14 PPP link up (Internet) [146.199.77.162]
Info Nov 30 06:18:11 PPP CHAP Receive success (Internet)
Info Nov 30 06:18:10 PPP CHAP Receive challenge from rhost JUNOS (Internet)
Info Nov 30 06:18:10 PPP CHAP Receive challenge from rhost acc-aln1.l-vik (Internet)
Info Nov 30 06:18:09 xDSL linestate up (ITU-T G.992.3; downstream: 6187 kbit/s, upstream: 888 kbit/s; output Power Down: 19.4 dBm, Up: 12.8 dBm; line Attenuation Down: 41.5 dB, Up: 23.2 dB; snr Margin Down: 6.2 dB, Up: 9.8 dB)
Info Nov 30 06:18:02 LOGIN User admin logged in on [HTTP] (from 192.168.1.66)
Warning Nov 30 06:17:45 PPP link down (Internet) [87.112.153.107]
Info Nov 30 06:17:43 xDSL linestate down
Info Nov 30 06:17:13 xDSL linestate down
Info Nov 30 06:16:56 xDSL linestate down
Error Nov 30 06:04:15 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 180.120.170.71 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Error Nov 30 05:56:09 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 119.184.71.251 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Error Nov 30 05:42:06 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 202.75.96.3 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
Error Nov 30 05:39:59 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 95.252.137.240 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Info Nov 30 05:39:46 SNTP Synchronised again to server: 212.159.13.50
Info Nov 30 05:34:40 LOGIN wireless station [84:7a:88:82:18:00] can't get authorized.
Error Nov 30 05:31:02 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 36.48.241.157 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Info Nov 30 04:39:45 SNTP Synchronised again to server: 212.159.13.50
Info Nov 30 04:34:40 LOGIN wireless station [84:7a:88:82:18:00] can't get authorized.
Error Nov 30 04:33:53 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 114.38.159.83 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Error Nov 30 04:19:02 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 119.149.151.218 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Error Nov 30 03:59:36 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 62.97.192.22 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Error Nov 30 03:49:29 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 201.48.66.117 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Host Unreacheable
Info Nov 30 03:39:45 SNTP Synchronised again to server: 212.159.13.50
Error Nov 30 03:13:03 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 119.56.219.170 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Port Unreacheable
Info Nov 30 02:39:45 SNTP Synchronised again to server: 212.159.13.50
Error Nov 30 02:33:39 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 99.119.50.78 Dst ip: 87.112.153.107 Type: Destination Unreachable Code: Communication Administratively Prohibited
Info Nov 30 01:39:45 SNTP Synchronised again to server: 212.159.13.50
Re: Do I have an issue?
30-11-2014 9:46 AM
It would be a good idea to post the TG582n Full DSL stats
What sync speed have you normally had of late?
30-11-2014 1:37 PM
The 6Mbps down speed has been quite standard for me for the time I've been with PN and is quite OK for what I do. I only got 6Mbps on LLU with o2. Of late though, and the reason I'm back on the forum, is my recent issue with upload speeds. Sometimes they drop to as low as 0.01 to 0.02 and as a result my security camera, as I've already mentioned, starts flashing 'no connection'.
Funnily enough, after todays outage my speeds are back to normal with the speed tester showing almost 6Mb and 1Mb.
I'm now seriously considering upgrading to FTTC to give me some extra oomph being as it's only another £5 a month for a 10Mbps down increase (the order line checker shows me as a realistic 16Mb / 6Mb). You wouldn't think I was in an urban area near Heathrow!
I did look at the upgrade process but it seems I have to take a phone deal on board at the same time. I'll ring in tomorrow as I pay my BT phone line every 12 months which is quite a bit cheaper and I still have some months left to run.
01-12-2014 5:06 AM
01-12-2014 5:08 AM
01-12-2014 8:35 AM
I think you have done the right thing
I had an iffy connection running at 5Mbps most of the the time. I went for FTTC which was estimated to give 15Mbps. Now I am getting 25Mbps with a brand new Mk 3 socket!
To be is to do - Kant
do be do be do - Sinatra
02-12-2014 5:33 AM
What did make me chuckle was that I opted for the 9th Dec from the list of available dates and then got an email an hour later telling me it would be the 15th.
Fitted another power socket near to the master socket for the OpenReach modem as I'm not a fan of adapters.
02-12-2014 6:53 AM
03-12-2014 10:23 AM
03-12-2014 1:07 PM
