Dispatch of fibre router - when?
- Dispatch of fibre router - when?
- « Previous
- Next »
Re: Dispatch of fibre router - when?
09-07-2014 12:30 PM
Hi Chris
Can you update status here? Or should I open a support ticket?
Thanks.
Thanks.
Message 31 of 35
(308 Views)
09-07-2014 1:09 PM
I've created Ticket: 88289769 for you so you can keep track of what's going on with this. The date on our suppliers systems have changed to 22/07/2014 PM Slot for a re-visit. I'll have our Provisioning Team chase this up to see what's going on and to get in touch with you further.
You'll be able to see the notes I've put on the ticket which I hope are clear on the issue.
Message 32 of 35
(308 Views)
10-07-2014 10:38 PM
On the plus side, two routers have now arrived.
Message 33 of 35
(308 Views)
10-07-2014 11:27 PM
Try and stick them together with blu-tack, you may end up getting a half decent wifi range.
Message 34 of 35
(308 Views)
10-07-2014 11:36 PM
That wont work, but sticking them together with ethernet cable a fair distance apart might.
Message 35 of 35
(308 Views)
- « Previous
- Next »
