Disconnects
mrbenray
Disconnects
For the last week or so I have been getting 3-4 disconnects a day resulting in me having to reboot my router each time. It's a real issue for me as it takes my smartthings hub offline and I lose lots of my home automation.  I was wondering if anybody had any ideas.
Here is the log for last disconnection:
12:59:59, 26 Sep.PPP LCP Send Configuration Request
12:59:56, 26 Sep.PPP LCP Send Configuration Request
12:59:53, 26 Sep.PPP LCP Send Configuration Request
12:59:50, 26 Sep.PPP LCP Send Configuration Request
12:59:47, 26 Sep.PPP LCP Send Configuration Request
12:59:44, 26 Sep.PPP LCP Send Configuration Request
12:59:41, 26 Sep.WAN Sensing Auto sensing Complete, interface selected
12:59:41, 26 Sep.PPP LCP Send Configuration Request
12:59:41, 26 Sep.PPP: Starting PPP daemon
12:59:39, 26 Sep.WAN Sensing Auto sensing Running
12:59:39, 26 Sep.WAN connection WAN3_INTERNET_ATM_0_38 disconnected.[ERROR_NO_CARRIER]
12:59:34, 26 Sep.PPP: Stopped PPP daemon(0,1,5)
12:59:30, 26 Sep.PPP LCP Send Termination Request (User request)
12:59:27, 26 Sep.PPP LCP Send Termination Request (Peer not responding)
12:59:27, 26 Sep.PPP: IPCP down
12:59:27, 26 Sep.PPP: LCP down
Many thanks
Ben
4 REPLIES 4
Alex
Fixes: 13
Re: Disconnects
Hi Ben,
Welcome to the forums.
Sounds like you may have a fault - have you tried the usual of disconnecting everything and trying the master socket using a wired connection to see if it makes any difference?
Is there any noise on the landline?
A member of staff should be able to post a Visual RADIUS log graph of your connection, but that doesn't sound right.
mrbenray
Re: Disconnects
Thanks for the reply. I have tried the tips you mentioned and made sure there was no noise on the land line, but I appreciate your time and suggestions.
Alex
Fixes: 13
Re: Disconnects
No problem,
Just to rule everything out your side really.
A Visual Radius will show there is probably a fault which will need to be raised I suspect.
MatthewWheeler
Fixes: 456
Re: Disconnects
Sorry to hear you're having issues.
Our tests aren't showing any cause for this but I can see the connection is dropping
I'd recommend raising a fault by going here.
 Matthew Wheeler
