Disconnects on Fibre broadband
- Disconnects on Fibre broadband
12-02-2012 8:45 AM
The disconnects seem to be getting more and more frequent and more frustrating!
Help please.
Re: Disconnects on Fibre broadband
12-02-2012 10:37 AM
12-02-2012 11:35 AM
My first gen OpenReach modem (wall mounted vertically) went through the same phase during a hot spell. A 6in desk fan blowing through it kept it alive until the replacement came a few days later. The constant DSL disconnects also wiped 15M off the sync speed which was reset by the OR Eng.
The replacement modem (June - ish) was the same type and so I still have the fan blowing on warm days This one hasn't lost sync, but then again I don't let it get hot!
I'm luckily having the replacement new style modem delivered/installed tomorrow, so hopefully the fan can be put away!
If you look at the underside of the router on the silver model number label, does it have any bold letters in the top right hand corner like 2B ?
Mine has nothing, but I believe the 'good ones' have either 2B or 3B in bold and the 3B apparently has a white PSU...
Pete
12-02-2012 11:37 AM
Mine has no 2B or 3B on it it has nothing. the psu is black. Wonder if ive got a dud. how do i go about changing?
12-02-2012 11:59 AM
Sounds like you have the same old version. As to replacement, BT OpenReach started a program of replacing the old with new 'heat proof' types as per 2B/3B via Kelly Communications.
I found on the Forum mention that PN were doing the same (Keyy Comms) and that letters were being issued soon and mine came yesterday to book a slot for them to install (presumably wall mounting being required) and test/reset etc.
I think it was relevant to anyone who had FTTC installed prior to September last year - doubtless someone will correct that date if wrong
But do try a fan on it as it restored mine to useable whilst the first one was being swapped out.
Cheers,
Pete
12-02-2012 6:36 PM
Quote from: cpembo78 I have noticed when ive been resetting that the modem is paticularly hot. not a great deal i can do as far as relocation goes ive got it sat on my desk so its not near anything that gets warm and all around it is clear.
One thing you can do to improve things, is to mount it vertically on a wall (or a piece of wood), so the word "Openreach" on the label can be read normally.
Don't block any of the slots though - you need to have a flow of air in from the bottom slots and out through the top ones.
Quote Mine has no 2B or 3B on it it has nothing. the psu is black. Wonder if ive got a dud. how do i go about changing?
That will be the old one - and it does sound dud.
You can wait for a letter & make an appointment with Kelly, or you can phone the fault in to the support guys (mentioning fibre, the disconnections, and the heat), and make sure they organise a change. It will mean an appointment with an Openreach engineer.
If, as a result of the disconnections, the modem is now syncing slower, you will need to mention that to the Openreach engineer, and ask him to phone through for the DLM to be reset. This will save you having to wait for the line to clear itself - which will take ages, and cannot be organised by anyone other than the Openreach engineer on-site!
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
12-02-2012 7:18 PM
13-02-2012 12:53 PM
How's it faired since?
Jojo
14-02-2012 5:04 PM
15-02-2012 12:01 PM
Hope it's been behaving and things are going well, have you been able to arrange an appointment to swap it out yet?
17-02-2012 6:58 PM
My other problem thats begining to show is that since ive signed up to netflix i have gone through my monthly allowance very quickly and am now having to manage my usage Very carefully! I cant find any options to upgrade above the 40gb cap, this is quickly going to become an issue as the kids are constanly asking to watch things on netflix.
17-02-2012 7:21 PM
18-02-2012 6:29 PM
19-02-2012 6:42 PM
Trying the fan method that was mentioned and i think ill have to give tech support a ring.
20-02-2012 4:26 PM
Yes, I'd advise contacting support. Where as it does sound like the modem could be a problem I wouldn't want for you to have to wait until you've had a letter from Kelly Comms or alternatively it be caused by something else altogether. Don't forget you can go <a href="https://portal.plus.net/apps/kbdfaults">here</a> if you don't want to call.
