Disconnections....
- Disconnections....
Disconnections....
14-09-2007 1:10 PM
I am currently connected to the "Telehouse North, Juniper 6" gateway. This gateway is sometimes known as thn-ag1.
Wonder if it stays there!
Edit.. happened again .. now connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
Edit .. and again
You are currently connected to the "Telehouse East, Juniper 4" gateway. This gateway is sometimes known as pte-ag2.
Re: Disconnections....
14-09-2007 1:27 PM
I'd recommend doing the standard filter anbd wiring checks and seeing if this improves anything. Otherwise raise a fault with us.
14-09-2007 4:45 PM
BT configured it so the line comes in for ADSL (before it hits the interior wiring) goes out again and then comes in for normal telephone. That way they didnt have to play with the interior wiring.
14-09-2007 4:49 PM
Let me know on Monday if you're having any difficulties and I'll be happy to take ownership.
14-09-2007 4:57 PM
Quote from: James Sounds good, thanks.
I am still having this problem and I have to work all this weekend .. it is a business connection. My problems start from tonight. It isnt a residential thing.
14-09-2007 5:01 PM
The Business Support Team are very good on Broadband Faults (as you would expect) so you'll be able to get timely updates. Should you give them a ring, you should have your call answered extremely quickly. Have you ever tried calling them before? (That's meant in a curious way, not an antagonistic one!).
14-09-2007 5:31 PM
I had a better response from Mand as to why I was experiencing problems on that occasion. Prior to that I had a cut and paste answer but that is just how it goes.
So far I am still connected for 25 minutes.
14-09-2007 5:38 PM
I would normally jump at the chance to help, but I'm leaving the office in 20 minutes and wouldn't be much help to you over the weekend!
17-09-2007 12:00 AM
The disconnection problem came out of the blue on Friday afternoon. It was then disconnecting at times every 15 minutes. I unplugged the router overnight and powered up in the morning. It did the same thing through the day on Saturday. I powered down overnight. On one or two occasions I had to manually disconnect because it seemed to be stuck in a cycle of trying to reconnect but was unable to do so. Sunday morning it did the same thing until about 11. Since then it has been stable for 12 hrs.
I am on Max and its synching at 8128 down and 832 up – that’s what’s showing on the router statistics.
My speed has dropped – it used to be near 7000 (6770 kbps to 6900 kbps). I have taken a number of tests here http://www.mybroadbandspeed.co.uk/ and although my upload speed remains the same approx 725 kbps the download speed has gone to 5140 kbps and at best 5170 kbps.
Is this a Max thing and will it return to normal levels? Also when I try to take the test for speed on www.dslzoneuk.net I get 5150 kbps as a speed.
17-09-2007 2:03 AM
Since your connection is now steady again with sync speed back to 8128kbps, the noise/fault may have been cleared and your IP profile should automatically increase; however the automated system takes up to 3 days to increase the profile. Rebooting the router once per day, and achieving an 8128kbps sync each time, can help persuade the monitoring equipment to increase your IP profile.
17-09-2007 9:45 AM
17-09-2007 10:01 AM
17-09-2007 4:29 PM
Well mes not panicking YET. Only a little bit!
17-09-2007 7:35 PM
