Disconnections
TheBigMass
Disconnections
For the past week ish, I've been getting disconnections sometimes which happen every 10 minutes or so. As of writing this, my Internet has went down at 13:12, 13:22, 13:32, 13:42 13:44. Any ideas?
Dec 25 13:44:47 FIREWALL event (1 of 2): deleted rules
Info Dec 25 13:44:47 GRP Default destination is routed via gateway 87.113.36.27
Warning Dec 25 13:44:46 PPP link up (Internet) [87.113.36.27]
Info Dec 25 13:44:46 PPP CHAP Chap receive success : authentication ok
Info Dec 25 13:44:46 PPP CHAP Receive challenge (rhost = PCL-AG01)
Info Dec 25 13:44:45 PPP CHAP Receive challenge (rhost = bras-red2.nt-b)
Info Dec 25 13:44:43 xDSL linestate up (ITU-T G.992.5; downstream: 17357 kbit/s, upstream: 1181 kbit/s; output Power Down: 21.0 dBm, Up: 12.5 dBm; line Attenuation Down: 22.0 dB, Up: 9.5 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Info Dec 25 13:44:18 xDSL linestate down
Warning Dec 25 13:44:14 PPP link down (Internet) [146.90.186.209]
Info Dec 25 13:43:52 LOGIN User Administrator logged in on [HTTP] (from 192.168.1.74)
Info Dec 25 13:43:52 xDSL linestate down
Info Dec 25 13:43:44 LOGIN User Administrator logged in on [HTTP] (from 192.168.1.67)
Info Dec 25 13:43:32 GRP Default destination is not routed anymore via gateway 146.90.186.209
Info Dec 25 13:43:32 xDSL linestate down
Info Dec 25 13:43:08 FIREWALL event (1 of 1): created rules
Info Dec 25 13:43:08 FIREWALL event (1 of 1): deleted rules
Info Dec 25 13:43:08 GRP Default destination is routed via gateway 146.90.186.209
Warning Dec 25 13:43:08 PPP link up (Internet) [146.90.186.209]
Info Dec 25 13:43:08 GRP Default destination is not routed anymore via gateway 146.90.186.209
Warning Dec 25 13:43:08 PPP link down (Internet) [146.90.186.209]
Info Dec 25 13:43:04 PPP CHAP Chap receive success : authentication ok
Info Dec 25 13:43:04 PPP CHAP Receive challenge (rhost = PTW-AG03)
Info Dec 25 13:43:04 PPP CHAP Receive challenge (rhost = bras-red2.nt-b)
Info Dec 25 13:43:02 xDSL linestate up (ITU-T G.992.5; downstream: 17290 kbit/s, upstream: 1170 kbit/s; output Power Down: 21.0 dBm, Up: 12.0 dBm; line Attenuation Down: 22.0 dB, Up: 9.5 dB; snr Margin Down: 6.0 dB, Up: 7.0 dB)
Warning Dec 25 13:42:38 PPP link down (Internet) [146.90.32.121]
Info Dec 25 13:42:36 xDSL linestate down
Info Dec 25 13:42:12 xDSL linestate down
Info Dec 25 13:41:51 FIREWALL event (1 of 1): created rules
Info Dec 25 13:41:51 GRP Default destination is not routed anymore via gateway 146.90.32.121
Info Dec 25 13:41:51 xDSL linestate down
Fixes: 71
Re: Disconnections
Something is certainly amiss.  Sad
I suggest reporting a dropping connection fault at http://faults.plus.net which will guide you through some checks then submit a fault report to Plusnet. This will provide initial data to support faults team testing.
David
Fixes: 5
Re: Disconnections
Yeah.  Get a fault raised.  These disconnections are pretty bad:
Kelly Dorset
Broadband Service Manager
